need a 4th gear synchro part number (pic)
Need the part circled in red below. The 4th gear brass synchro for ITR trans. All the parts sites I checked only show the synchro set, not each individual piece. My 4th gear and synchro are shot, so I only need 4th gear side. Is it even possible to buy this separately or do you have to buy the set?
I believe gear speed sells individual synchros. They are or where at one point an HT sponsor. I don't have the contact info handy but I'm sure someone will chime in with it.
I know from Honda you can only buy the set. Gearspeed allow you to buy stuff seperately. Check out there site and see if joo can find what you need...
http://www.gearspeedinc.com/home.htm
yeah Ive been sitting here all morning researching and for whatever reason Honda does not sell those parts separately. stupidest thing Ive ever heard if you ask me. I will check out gearspeed
side note, anyone looking to rebuild their ITR tranny might want to look into parts for a B16 trans. Parts for that tranny, which appear to be the exact same as the ITR tranny, are SO MUCH CHEAPER. For instance, the countershaft needle bearing in the clutch housing for the ITR is $62 from Baranco. The SAME bearing for a B16 tranny from Majestic is $23!!
needless to say when all was said and done, I saved about $100 in parts on my order this morning.
Modified by RTW DC2R at 11:21 AM 10/16/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">yeah Ive been sitting here all morning researching and for whatever reason Honda does not sell those parts separately. stupidest thing Ive ever heard if you ask me. I will check out gearspeed
Modified by RTW DC2R at 11:21 AM 10/16/2006</TD></TR></TABLE>
Be careful - some of the parts in the b16 tranny are NOT the same. Their dimensions are different.....!
all the bearing dimensions are the same (atleast the ones I needed). so if the 4th gear isnt the same then Ill just send it back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedR »</TD></TR><TR><TD CLASS="quote">good luck with the fixing
go crawl back under your rock MJ lol
anyway Gearspeed has NO synchros available until the end of November. Anyone have any other ideas besides buying a new synchro set? what if I dremel down the teeth some to reshape them? Im pretty good with the dremel lol
</TD></TR></TABLE>go crawl back under your rock MJ lol
keep searching...and check the FAQ at the top
https://honda-tech.com/zerothread?id=1597005
user IN VTEC also made a great thread as well.
kaj
Transmission & Drivetrain
Oct 31, 2010 07:57 PM
Ehron
12
Mar 29, 2003 02:53 PM
