Suspension & Brakes Theory, alignment, spring rates....
bushing condition, what do u guys think?
Old Oct 15, 2006 | 06:28 PM
De_tour's Avatar
Default bushing condition, what do u guys think?
Modified by De_tour at 3:03 PM 5/2/2007
Old Oct 15, 2006 | 11:18 PM
super_nguyen's Avatar
Default Re: bushing condition, what do u guys think? (wspcivic)
i've seen worse, just clean it up and it should be good to go, make sure to use anti seize so that metal sleeve inside the bushing doesn't stick to the bolts.
Old Oct 16, 2006 | 12:12 AM
chrisw85's Avatar
worn. replace. you already have it all apart. new bolts too.
Old Oct 16, 2006 | 09:20 AM
Tyson's Avatar
just depends on how deep its cracked through.
and ive seen A LOT worse than that.
Old Oct 16, 2006 | 02:09 PM
dvp's Avatar
dvp
Default Re: bushing condition, what do u guys think? (Tyson)
Those bushings cost about 5 bucks each...do it right and you wont have to worry about it in the future...for a while anyways.
Old Oct 16, 2006 | 02:25 PM
DavidR's Avatar
Default Re: bushing condition, what do u guys think? (dvp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvp &raquo;</TD></TR><TR><TD CLASS="quote">Those bushings cost about 5 bucks each...do it right and you wont have to worry about it in the future...for a while anyways.</TD></TR></TABLE>
With what you pay to have them pressed out/in, its almost cheaper to buy a new set of LCAs from the dealer. Cheap aftermarket LCAs use worse materials than the stock bushings, do don't bet on those lasting very long.
Old Oct 16, 2006 | 02:34 PM
dvp's Avatar
dvp
Default Re: bushing condition, what do u guys think? (DavidR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR &raquo;</TD></TR><TR><TD CLASS="quote">With what you pay to have them pressed out/in, its almost cheaper to buy a new set of LCAs from the dealer. Cheap aftermarket LCAs use worse materials than the stock bushings, do don't bet on those lasting very long. </TD></TR></TABLE>
The shop up the street from me did mine for free...asked me to bring them donuts instead. It takes less than 5 minutes to set up the press and about 1 minute a piece. Why would he use cheap bushings if they can be purchased from the dealer for cheap?
Old Oct 16, 2006 | 02:39 PM
Tyson's Avatar
theyre more like $15 or more from honda.
they may be $5 from aftermarket, 'OEM quality' resellers.
at $130 for a pair of NEW lca, it was worth it to me to buy than buying the bushings indvidually and having them pressed in. simple math $15 x 6 = $90
Old Oct 16, 2006 | 03:06 PM
dvp's Avatar
dvp
Well I was absolutely wrong about the price. Their more than I'd remembered.
Thwe other option is Poly bushings.
Old Oct 16, 2006 | 03:37 PM
De_tour's Avatar
Modified by De_tour at 2:32 PM 2/22/2007
hybrid90
Jan 22, 2008 03:31 PM
BDogggUT34
Aug 31, 2007 12:34 PM
blaze_125
May 24, 2007 11:26 AM
lowcivex
Suspension & Brakes
34
Feb 26, 2007 05:55 PM
Liquidgsr
Apr 18, 2004 07:36 PM
