D16A6 with 75 shot. 255 or 190 lph Fuel pump?
I'm getting ready to order my Walbro Fuel Pump for my 75 shot nitrous setup. Should I buy the 190lph, 255lph LP, or the 255 lph HP? I wan't to have enough fuel for the nitrous but not have to mess with my idle pressure.
i've had 255's in stock-engine'd cars, and they idled perfect...
bigger the better IMO....but either would work fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch »</TD></TR><TR><TD CLASS="quote">i've had 255's in stock-engine'd cars, and they idled perfect...
bigger the better IMO....but either would work fine.</TD></TR></TABLE>
What engine was it? I'm sure a bigger dual cam would accept the added fuel pressure better. My little SOHC may not like it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheHooded_Mike »</TD></TR><TR><TD CLASS="quote">The stock fuel pump is fine for a 75 shot anyway...</TD></TR></TABLE>
I've heard, but i'm a paranoid ************. Here's my total setup:
-Retard timing 3 deg.
-Two stage colder NGK plugs.
-Cometic HG.
-ARP headstuds.
-MSD window switch.
-Walbro (?)lph fuel pump.
-Run Sunoco 116 when spraying.
I'm thinking the 190 should be fine...
-Cometic HG.
-ARP headstuds.
-MSD window switch.
Well, i wasn't worried about the price, in fact my supplier has them 4 the same price.
I just wanted to know if the 255 would **** with my idle or fuel pressure.
I'm just gonna strap all the stuff I listed on, and go to a dyno. Let them sort out my A/F ratio and I'm done.
when i was turboing my car i installed my walbro 255 way before i put in my turbo kit and my car idled fine and nothing changed at all
if i were you i'd spend the extra 10 bucks, you'll be glad you did it in the future
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger »</TD></TR><TR><TD CLASS="quote">when i was turboing my car i installed my walbro 255 way before i put in my turbo kit and my car idled fine and nothing changed at all
if i were you i'd spend the extra 10 bucks, you'll be glad you did it in the future</TD></TR></TABLE>
SiR831
Aug 14, 2005 05:05 AM
DroppedTegra
Jan 18, 2002 03:13 PM
