Exhaust heat shield, which is better SS or Aluminum?
Old Oct 15, 2006 | 05:54 PM
danielm3's Avatar
Default Exhaust heat shield, which is better SS or Aluminum?
I was thinking about this the other day with a friend and we couldn't come up to an agreement for which one is better. I think SS would be a better header heat shield since it can resist much higher temps and doesn't absorb heat as fast as an Aluminum.. now I know Aluminum is used for a lot of shields and we all know aluminum get rids of heat a lot faster, but in the case of a heat shield you don't want the heat to dissipate in to the engine bay, but stay under the shield.
So which would be better? what do you guys think?
Old Oct 15, 2006 | 05:55 PM
nowtype's Avatar
Default Re: Exhaust heat shield, which is better SS or Aluminum? (danielm3)
Stainless would be the best choice for basically the reasons you stated. You could also just use mild steel and spray it with BBQ paint.
Old Oct 15, 2006 | 06:27 PM
beepy's Avatar
Default Re: Exhaust heat shield, which is better SS or Aluminum? (nowtype)
I would use aluminum for lightness and ease of workability, and then put a layer of heat-resistant fiberglass matting in there to do the work of the heat shield. DEI makes a 4' x 3' sheet of insulating and refective matting for about $50, and that is enough material to make a lot of heat shields:
http://store.summitracing.com/...10682
Old Oct 16, 2006 | 11:58 AM
danielm3's Avatar
Default Re: Exhaust heat shield, which is better SS or Aluminum? (beepy)
good ideas. Thanks.
8YourV8
17
Dec 31, 2010 04:14 PM
mrx
Mar 18, 2005 06:38 AM
Charlie Moua
Sep 13, 2002 04:52 PM
Spade
23
Jul 30, 2002 04:27 PM
stealthteg
Apr 18, 2002 11:30 AM
