ls brakes on ef?
Old Oct 15, 2006 | 04:53 PM
russianswty's Avatar
Default ls brakes on ef?
ok so im putting obd1 ls da brakes my ef, but I want to keep my stock wheels,
ive got 14's, cant I just use wheel spacers.
I saw a integra with hx rims on there. And i figured since you can do that
I should be able to use the 14 inch wheels,
Where can I find some of these wheel spacers?
Old Oct 15, 2006 | 05:16 PM
EL Vap133's Avatar
Default Re: ls brakes on ef? (russianswty)
It will clear most 14" wheels.
Old Oct 15, 2006 | 05:30 PM
Default Re: ls brakes on ef? (EL Vap133)
oh really? hmm, so if i have the stock si tear drops, i can install the integra brakes and not have to worry about the wheels fitting.
Old Oct 15, 2006 | 05:39 PM
nutz4cycling's Avatar
I tried to put one of my stock 14" Si teardrop rims on my 1990 teg, and once it was tightened down it would not turn, the caliper was hitting the rim. it might fit with a spacer, but I cant say for sure as I have not tested it.
Old Oct 16, 2006 | 09:32 AM
Default Re: ls brakes on ef? (nutz4cycling)
where can i buy wheel spacers? Is that something that needs to be ordered.
Or can I go down to my local parts store and pick some up.
Hows big of a spacer do you guys thing I would need.
Old Oct 17, 2006 | 12:36 PM
Should I use any of the stock crx parts? cables, lines, master cylinder,
Or should I swap all that over with the proportioning valve and everything.
Oh I think im just going to use all the integra parts and just throw a camber
kit on there. Instead of searching for 90/91 ex parts.
any input. suggestions, tips, concerns.
96accordsir
Nov 21, 2008 09:06 PM
PhatBoy5015
Oct 18, 2005 11:09 PM
mdmitch2
10
Jun 23, 2005 03:34 PM
menappi
Mar 1, 2005 09:40 AM
enthusiast128
Nov 10, 2001 07:57 AM
