Crx zc cable lsd tranny?
Old Oct 15, 2006 | 03:53 PM
boylovecar's Avatar
Default Crx zc cable lsd tranny?
I was under the impression that I was to use some integra axle half shaft combo, but my mechanic told me to just use the stock si axles. Is this possible? Unfortunately the ZC tranny I purchased did not come with the half shaft, so would it be possible to use the DA or 86-89 teg half shaft? Or what is the simplest way to use this thing? I read of someone using just the crx driver side axle and DA passenger side axle only. That seemed simple enough, is that possible? Thanks in advance for helpful idea's and anwers.
Old Oct 15, 2006 | 03:56 PM
Tippyman's Avatar
Default Re: Crx zc cable lsd tranny? (boylovecar)
90-93 Integra Non-ABS Axles. Use DX or Si hubs.
Old Oct 15, 2006 | 07:09 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boylovecar &raquo;</TD></TR><TR><TD CLASS="quote">I was under the impression that I was to use some integra axle half shaft combo, but my mechanic told me to just use the stock si axles. Is this possible?</TD></TR></TABLE>
no - but you do need to find a mechanic that knows something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Unfortunately the ZC tranny I purchased did not come with the half shaft, so would it be possible to use the DA or 86-89 teg half shaft?</TD></TR></TABLE>
no - wrong bolt pattern
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Or what is the simplest way to use this thing?</TD></TR></TABLE>
get a ZC intermediate shaft and right and left 90-93 Integra axles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I read of someone using just the crx driver side axle and DA passenger side axle only. That seemed simple enough, is that possible? </TD></TR></TABLE>
no, that is not possible
Old Oct 15, 2006 | 07:21 PM
civicjdmb16a's Avatar
Default Re: Crx zc cable lsd tranny? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">
no, that is not possible</TD></TR></TABLE>
This man knows his ish
Tippyman's Avatar
^ Man knows his ****.
Old Oct 15, 2006 | 07:31 PM
JDM_DC4_Fanatic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">^ Man knows his ****.</TD></TR></TABLE>
x2
Old Oct 16, 2006 | 02:43 AM
boylovecar's Avatar
Default Re: Crx zc cable lsd tranny? (JDM_EK_Fanatic)
Thank you sir. Is there any place that may sell this halfshaft that comes to mind?
Old Oct 16, 2006 | 04:39 AM
Voodooboy520's Avatar
Ebay. I thought about doing a ZC trans, but I decided to go with a ZC\Si hybrid with a HF 5th. Best of both worlds :D . If you need help, shoot me a PM.
Old Oct 16, 2006 | 01:37 PM
boylovecar's Avatar
Default Re: (Voodooboy520)
Seems like patience will be key here. One more thing, there was something I read about the dirt guards being needed to be removed?
Old Oct 16, 2006 | 01:40 PM
crxgator's Avatar
Default Re: (boylovecar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boylovecar &raquo;</TD></TR><TR><TD CLASS="quote">Seems like patience will be key here. One more thing, there was something I read about the dirt guards being needed to be removed?</TD></TR></TABLE>
dust ring on the back of the knuckles (where the axle goes in)...
Old Oct 16, 2006 | 01:43 PM
Tippyman's Avatar
Call Steve at Hmotorsonline.com. He may have some around there.
Old Oct 16, 2006 | 02:35 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boylovecar &raquo;</TD></TR><TR><TD CLASS="quote">Thank you sir. Is there any place that may sell this halfshaft that comes to mind?</TD></TR></TABLE>try this guy - don't know if he still has it
http://www.thezcr.com/forums/s...shaft
honda_coupe
Mar 8, 2009 06:40 AM
jitr
Jan 28, 2008 05:05 PM
ktp1798
Aug 22, 2005 01:42 PM
d357r0y
Sep 13, 2003 06:49 AM
afstlsvtec
19
Mar 19, 2002 04:03 AM
