cleaning 02 sensor
Old Oct 15, 2006 | 02:49 PM
Suck my DX's Avatar
Default cleaning 02 sensor
Old Oct 15, 2006 | 03:00 PM
Perfectionist's Avatar
Default Re: cleaning 02 sensor (Suck my DX)
You might have some luck cooking it with a propane torch if it's only carbon or burned oil deposites. If it's contaminated by the silicates in the coolant, not so good.
Old Oct 15, 2006 | 03:02 PM
Suck my DX's Avatar
Default Re: cleaning 02 sensor (Perfectionist)
yeah its just got a lot of carbon buildup on it...dont know if a torch is gonna get rid of it...maybe go at it lightly with sum 400 grit sandpaper?
Old Oct 15, 2006 | 03:37 PM
89 civic si's Avatar
i think the o2 sesnor is pretty fragile i think the sandpaper may work...i had to buy a new one try out hopefully it works
Old Oct 15, 2006 | 04:00 PM
Ak_ef9's Avatar
Default Re: cleaning 02 sensor (89 civic si)
I wopuld not suggest cleaning it. it will get residue on it and make it run wierd for a while. or uniss the buildup starts baxck up again. a new o2 sensor is only about 18 dollars so just replace it and you dont have to deal with the hassle of it coming up with a code later on.
Old Oct 15, 2006 | 04:01 PM
Ak_ef9's Avatar
but I guess if you really wanted to I would use a clean towel and some of that electronic parts cleaner. that stuff doesnt leave alot of resedue and works fairly good.
Old Oct 15, 2006 | 04:03 PM
Global688's Avatar
Just buy a new one. I bought a bosch one for 28$ today to replace the one in my car. Actually was kinda funny there wasno sensor left. My old blown engine musta took it out.
Old Oct 15, 2006 | 04:33 PM
Suck my DX's Avatar
Default Re: cleaning 02 sensor (Ak_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">I wopuld not suggest cleaning it. it will get residue on it and make it run wierd for a while. or uniss the buildup starts baxck up again. a new o2 sensor is only about 18 dollars so just replace it and you dont have to deal with the hassle of it coming up with a code later on. </TD></TR></TABLE>
the residue will make it run weird? what in the world are you talking about?
just blow off anything left over with compressed air and the exhaust gas will take care of the rest...
can anyone give me a positive answer?
Old Oct 15, 2006 | 04:38 PM
d16vtecx's Avatar
i had a code for o2
took it off scrubbed it with a wire brush and now its cool
Old Oct 15, 2006 | 04:51 PM
Ak_ef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">
can anyone give me a positive answer?</TD></TR></TABLE>
sounds like you have all the answers. do it
Old Oct 16, 2006 | 08:14 AM
Suck my DX's Avatar
Default Re: cleaning 02 sensor (d16vtecx)
yeah i had a bosch before, and i never had any problems...but my buddy was doing a street tune on the car saturday night and i guess i left the o2 dangling too low and it got ripped off when we were going around the block...
i still have the two stock o2 sensors, but they have a lot of carbon buildup on em....so yeah im gonna try going at em with some red scuff and see what happens...im just broke right now and buying a new one is not an option...
what would happen if i gave it a quick blast of brake cleaner?
Old Oct 16, 2006 | 10:39 AM
Well, you could google for information and decide if the information is valid or not, just like advice on these forums.
I did a brief search and found these in no particular order...
Clean it with a propane torch
Disconnect the sensor and create a lean condition on a warm engine by removing a vacuum line and run at 2000 rpm for 2 minutes.
And.. Never clean the sensor with solvents. Contamination will ruin the sensor.
adude2003
Honda Civic (2001 - 2005)
May 29, 2008 03:06 PM
amej8
Jul 11, 2006 06:25 PM
l2yanE
Sep 1, 2005 09:05 AM
yeegsr
Nov 21, 2004 08:37 PM
Casey
May 16, 2002 08:03 PM
