putting an acura cl type s motor into a 99 si shell
How hard would it be to put an acura cl type s mototr into a 99 si shell?
How hard would this swap be, would the motor and tranny fit into the chassis??
Has anyone ever done this before??
Considering the following...The axles, the motot mounts, the OBD of the wires, The layout of both things like intake and other things compared to civic.
or
or
I saw it done on an EG hatch on one of the nopi tunervision episodes awhile back so I know it's possible....definately make an awsome sleeper if you supercharged it. Don't know anything about it because I've never seen it done before (or even after that), but good luck if you attempt it.
I'd also like to see this...i own a 03 auto TL type s and this shiet hauls *** for a 4 door with only a Comptech airbox...I pull swapped civics occasionally...but those days are done since i had to warranty the trans recently.
