forged pistons pn stock rods??
Old Oct 15, 2006 | 01:12 PM
turbo boost's Avatar
Default forged pistons on stock rods??
is it much work to put forged pistons on stock ls rods??..what all is needed to be done???
Old Oct 15, 2006 | 01:26 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: forged pistons on stock rods?? (snowbunny)
yeah but you will still be limmited in power with the stock rods. if you are goin that far, replace the rods.
Old Oct 15, 2006 | 01:35 PM
Default Re: forged pistons on stock rods?? (boostedcivicsir)
what is needed to be done to put them on?
Old Oct 15, 2006 | 01:59 PM
Weston's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">yeah but you will still be limmited in power with the stock rods. if you are goin that far, replace the rods.</TD></TR></TABLE>
Plenty of people are making good power on stock LS rods. See this thread... https://honda-tech.com/zerothread?id=1777215
I intend to shot-peen my stock LS rods and put forged pistons on them.
Old Oct 15, 2006 | 02:16 PM
Default Re: forged pistons on stock rods?? (Weston)
so all that is needed to do is have a shop hone out the pin side of the stock rod to accept the new bigger pin?
Old Oct 15, 2006 | 02:58 PM
Old Oct 15, 2006 | 03:25 PM
VtecnTurbo's Avatar
yes drop stock rods with pistons,rings, & lock pins at machine shop and they will put them on the rods
Old Oct 15, 2006 | 03:39 PM
Mr. Badwrench
stupid question, but how much does shot peening, and setting up for a bushed small end out weigh a good set of forged rods? to me it just would suit better to use a set of better rods that in the end would net a better gain with the forged pidtons, maybe i am just not thinking this all the way through. am i not getting something?
Old Oct 15, 2006 | 03:43 PM
CroteTurbo's Avatar
Yes just have them hone for the floating pins, my shop also make a small hole on top of the rod to allow oil to get to the floating pin.
Beleive me, save money and buy some forged rod! I juste bend an ls rod at 320whp, now I need to rebuilt. And don't tell me you won't go to that power, you will...
Old Oct 15, 2006 | 03:55 PM
Default Re: forged pistons on stock rods?? (CroteTurbo)
really?..i thought ls rods would take more then that??
Old Oct 16, 2006 | 07:33 AM
CroteTurbo's Avatar
they might go higher than that, but for how long?
It may be my tune that kill the rod, don't know.
I did 2 years at 295whp and they hold.
I up the boost from 10.5 to 13.5psi and it bend, I just estimated the power to 320whp, but it may have been more than that.
But my advise stay, get some rods.
Old Oct 16, 2006 | 09:06 AM
b18sihatch's Avatar
replace the rods too, that is completely stupid to just og with forged pistons, you might as well not even get those... why not do it right the first time?
and if money is a issue save up and do it right! not half assed
having forged pistons will limit you in boost pressures and eventually just snap the rods, so might as well do it now instead of later
Old Oct 16, 2006 | 09:41 AM
Schister66's Avatar
Man U FTW
idk why you wouldn't just replace them when you have it all apart.....just for peace of mind if nothing else
OT: Does anyone know the limit on stock GSR rods? I'm building my new setup to see the limit on stock internals....
Old Oct 16, 2006 | 01:04 PM
Default Re: (Schister66)
i just wanted to make 280-300whp and that be it...so thats y i thought id just get forged pistons..its a dd so i dont want nothin to crazy
slowtegkauai
Mar 19, 2008 10:08 PM
allhonda
Jul 23, 2007 01:20 PM
lilpastrana
Apr 17, 2007 03:45 PM
hotimportcrx
10
Sep 6, 2005 10:39 PM
gunmetalcivic
Mar 22, 2004 09:38 AM
