My 18G+SuprDave
Old Oct 15, 2006 | 09:34 AM
urbansi's Avatar
Default My 18G+SuprDave
Well i finally got out to Whipfactory yesterday evening. Simple 18G on a stock bottom end'd B16, 3in dp and exhaust with 525cc injectors Tuned on Neptune
The goal was 240-250whp in the end, but on the first pull it made 249whp...Needless to say i was pretty excited...
So after about 3-4 hours we finally got some amazing peak numbers out of the car. For all you non-believers out there. About 9 PSI
So after our last pull we noticed some smoke coming out of the valvestem breather...after a lttle while we dismissed it and took it off the dyno...
So as planned that day we headed right to the track later for some timed runs...
I only got one run in which was a 13.2@110 with a terrible 2.24 60'...
And then i fried some rings(pretty sure it was do to a boost spike)... But i must say the power on the street felt so amazing, i never felt my car break the tires loose at 40mph with a drag radial on it. Too bad wont feel that power again for a couple of months.
We were laughing after the tune, calling it "The little 18G that could"
And Dave thanks again for a fun couple of hours and letting me squeeze all the information out of you that i could, it was a great day even though my car blew up...
Time for my build i guess, wiseco's and eagles have been waiting.
Modified by urbansi at 11:05 AM 10/16/2006
Old Oct 15, 2006 | 09:39 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: My 18G+SuprDave (urbansi)
How'd you crack your stock ringlands at only 275whp? Beating on it untuned?
Old Oct 15, 2006 | 09:44 AM
blaze the chemi's Avatar
Default Re: My 18G+SuprDave (boostincoupe)
I take it you do not have A/C with a 3 in DP in the 18G kit? I have the stock kit too but I only got up to 248whp @ 12 psi with a stock diameter exhaust. Good luck with rebuild. It is fun and rewarding in the end if you plan on doing it yourself.
Old Oct 15, 2006 | 09:52 AM
urbansi's Avatar
Well in the past i was on a street tune but only making 215whp...
The car got tuned on Neptune the same day it blew, i just think the motor was kinda tired in the first place and shouldnt have been pushed as far as it was...
Old Oct 15, 2006 | 09:55 AM
1boostedcivic's Avatar
wow thats pretty sad. good luck with the new build!! how is the spool on the 18g with a b16?
Old Oct 15, 2006 | 09:58 AM
urbansi's Avatar
Default Re: My 18G+SuprDave (1boostedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1boostedcivic &raquo;</TD></TR><TR><TD CLASS="quote">wow thats pretty sad. good luck with the new build!! how is the spool on the 18g with a b16?</TD></TR></TABLE>
Dude....amazing, look at the dyno, the little facker pulled all the way to redline, full boost at 3100rpm till redline...i love this turbo.
Old Oct 15, 2006 | 11:06 AM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">How'd you crack your stock ringlands at only 275whp? Beating on it untuned? </TD></TR></TABLE>
my b16 only made 240-250hp and the ringlands cracked too. did it while on the dyno going for 300hp
Old Oct 15, 2006 | 12:44 PM
Schister66's Avatar
Man U FTW
i dont know how you made that much power on that little turbo at such low boost.....i have a T3/T04E 60 trim on 9psi and made the same #'s...i guess its because you're on 93, i'm on 91....i have a log, you probably dont....i have a 2.5" exhaust, you have a 3".....
sucks that your car blew up, but it will be more fun once its built....
Old Oct 15, 2006 | 12:54 PM
JDM_EM1's Avatar
Default Re: (Schister66)
lol same **** happened to me, just on a different setup. nice numbers tho
Old Oct 15, 2006 | 01:42 PM
urbansi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">i dont know how you made that much power on that little turbo at such low boost.....i have a T3/T04E 60 trim on 9psi and made the same #'s...i guess its because you're on 93, i'm on 91....i have a log, you probably dont....i have a 2.5" exhaust, you have a 3".....
sucks that your car blew up, but it will be more fun once its built.... </TD></TR></TABLE>
Nope i was still on the stock greddy log manifold, just with a v-band discharge and 3in straight turbo-back exhaust... If you watch the video's i posted you can hear how loud the car was, now it just sounds like a WRX
Old Oct 15, 2006 | 01:45 PM
TallKyle's Avatar
Default Re: (urbansi)
That sucks Trent. If you need help with it , you know who to call.
for WhipFactory
Old Oct 15, 2006 | 01:47 PM
TheHooded_Mike's Avatar
Dude, the 18g isn't that small...it can make 350+...
Old Oct 15, 2006 | 02:30 PM
SOHCD16y8's Avatar
About how much is an hour or two of dyno tuning cost these days at the whip factory?
Old Oct 15, 2006 | 02:40 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">i dont know how you made that much power on that little turbo at such low boost</TD></TR></TABLE>
good tune.
was this the motor you have had in the car for a while?
im sure it has been drivin pretty good
Old Oct 15, 2006 | 02:44 PM
urbansi's Avatar
Default Re: (blackeg)
Motor had 94k on it...boosted the last 27k, hard might i add.
Old Oct 15, 2006 | 03:47 PM
adseguy's Avatar
Trent, what's up man! The SI is gone then huh?
Worries me that it happened the same day. You're not really "pushing it" with that kind of HP. What kind of compression numbers do you get across the board? I hope it wasn't detonation that killed the motor. Take some pics of the pistons when you rip it apart.
273 @ 9psi on that little 18G...nice! Where are the torque numbers and A/F's? Anyway good run and hope the build up goes smoothly
Old Oct 15, 2006 | 03:56 PM
Default Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">273 @ 9psi on that little 18G...nice!</TD></TR></TABLE> Again, it's not that small of a turbo...capable of 350+ man.
Old Oct 15, 2006 | 04:29 PM
urbansi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Trent, what's up man! The SI is gone then huh?
273 @ 9psi on that little 18G...nice! Where are the torque numbers and A/F's? Anyway good run and hope the build up goes smoothly </TD></TR></TABLE>
Well its not gone, but its down for a little while... i need some time to pull the motor and send it to the machine shop. Hopefully i can get it up and running before the end of christmas break.
My guess is that the internal wastegate spiked pretty heavily and took out a piston or two, Dave was telling me that my boost gauge was off compared to what the 3-bar was reading or whatever.
Yeah and 273whp was pretty wild for the 5 hours that it lasted, the powerband was sick as hell... but it will be back and better than ever soon.
Old Oct 15, 2006 | 05:49 PM
90LSpimpin's Avatar
Good numbers man Your car's always been impressive, lookin forward to see what your build does. Although had you used more JB Weld and zip ties in your setup, it probably woulda lasted longer
Old Oct 15, 2006 | 06:34 PM
second edition's Avatar
Default Re: (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">About how much is an hour or two of dyno tuning cost these days at the whip factory?</TD></TR></TABLE>
I wana know too..its semi close to me and ive heard its reputable
Old Oct 15, 2006 | 06:49 PM
urbansi's Avatar
Default Re: (90LSpimpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90LSpimpin &raquo;</TD></TR><TR><TD CLASS="quote">Good numbers man Your car's always been impressive, lookin forward to see what your build does. Although had you used more JB Weld and zip ties in your setup, it probably woulda lasted longer </TD></TR></TABLE>
Hey thanks bud, and let me know when you beat my 13.2@110....thats the new number for ya to work at
Old Oct 15, 2006 | 06:51 PM
90LSpimpin's Avatar
Stuck at 13.79 right now, havent been back though, car is NA at the moment, new things to come veerrry soon
Old Oct 15, 2006 | 07:10 PM
urbansi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90LSpimpin &raquo;</TD></TR><TR><TD CLASS="quote">new things to come veerrry soon </TD></TR></TABLE>
hey join the club
Old Oct 15, 2006 | 07:17 PM
I bet your bottom end looks like this right now.
After the rebuild it should look like this:
Good luck
Old Oct 15, 2006 | 10:28 PM
SL0WEGG's Avatar
Default Re: (blaze the chemi)
i dont know but clicking on the video showed your photobucket images and for some reason i was stuck on this
