what head should I use for ls vtec?
Old Oct 15, 2006 | 09:16 AM
tavius44's Avatar
Default what head should I use for ls vtec?
hey I was woundering which head would be better to put on top of a b18a1 (ls) a b16 head, gsr head or type r head, please let me know which one would be the best thanks
Old Oct 15, 2006 | 10:45 AM
user 25438239's Avatar
Default Re: what head should I use for ls vtec? (tavius44)
a VTec one
Old Oct 15, 2006 | 10:46 AM
ilikejesus's Avatar
i'm goin gsr!!! wooo!!! lol
Old Oct 15, 2006 | 10:48 AM
invisible's Avatar
Default Re: what head should I use for ls vtec? (ilikejesus)
b16 head, has better flow than a gsr. or if you have the money a type r one.
Old Oct 15, 2006 | 10:52 AM
for the money, go b16 head
for great flow, go b17 head.
Old Oct 15, 2006 | 11:20 AM
ghonaherpalitis's Avatar
b16
Old Oct 15, 2006 | 11:40 AM
4dOoR-Ex's Avatar
do it rite the first time.!!
Old Oct 15, 2006 | 11:41 AM
4dOoR-Ex's Avatar
Ls/vtec is the mating of the B18A/B to a B-series Vtec head like the B18C1, B18C5, B17A or B16A head. The amazing part about this swap is that the Ls blocks did not come with Vtec so there are a few mods you need to know to do the swap right.
A. GENERAL INFORMATION
1. The Down Side. The B18a/b has a low r/s ratio 1.53 which is not bad compared to the 1.58 of a gsr. The b18a/b was not made to rev over 7000 r.p.m's so it has poor lubrication, bad rod bolts, rods, oil and water pumps, and piston valve relief’s. You can fix all these problems, as you can install vtec block oil squirters for lubricating the rods and piston. This helps to save the pistons, rods and bearings at high rpm's. You can install ARP rod bolts. And get upgraded rods or shot-peined. Also some vtec pistons are recommended.
2. Oil lines. The Ls block does not have a Vtec oil passage (you need this hole to produce the oil pressure to lock the vtec lobes rocker arm) so you will need to tap the hole on the head or weld it shut. When threading it shut use a 1/8ntp fitting. Its best to have a machine shop thread it for the 1/8th fitting and then just screw it in. Next you have to make an external line from the oil pressure sender to the head. Use a 4an to 3/8th ntp plug on the head to a steal braided line to tee'd of to the oil pressure sender hole. You will need a 1/8th tee fitting, a 1/8th to 3/4th's fitting for the line to the tee, a 1/8th to 1/8th adapter to plug the block, and plug the oil pressure sender in the back of the tee. So it will look like this (the T will be used as the tee fitting) 18th to 1/8th adapter T oil pressure sender sensor oil line to head. A suggestion is to have the tee fitting so it is not directly on the block (especially if you are installing an oil pressure gauge) as it can literally crack the threads and you will shoot oil everywhere. So try to run ss lines to someplace that can support the weight.
3. You will use the Ls head gasket.
4. Dowel pins: The head needs to be modified for the dowel pins to fit. You have to move and re-drill the dowel pins to be able to fit the head. On the intake side right below where you put the 1/8pipe fitting that plugs the vtec oil passage, you will drill and install one of the dowel pins and do the same on the other side at the exact same point.
5. Timing belt. You will use the Ls timing belt if you use the Ls water pump and the gsr if you use a vtec B17/16 or B18c1/5.
6. Head studs. You will use the vtec head studs for the ls/vtec set-up. I suggest ARP if you want to spend the money.
7. Oil Pump. The oil pumps on the ls's suck so you might want to upgrade to a vtec one or a b20 as they are same part number as the gsr.
8. Heads. There are many heads you can use and there are little differences between them.
First off there is the GSR head which give you a higher compression than the other b-series heads because of its 41.6cc combustion chamber. The smaller combustion chamber makes .2 more compression. Then there is the b16/17a head which are the same the only difference is that the b17a has a p61 stamped on the back of the intake manifold the b16/17a head is a better flowing head 5.25% in fact and a larger combustion chamber 42.7cc's. Then there is the type r which flows even better than the b16a head and has the same combustion chamber. To put this in perspective the b18a/b has a 45cc combustion chamber.
9. GSR Block Girdle. You can use the GSR block girdle on the ls. This will reinforce the bottom end and keep the moving parts in its place. All you need to get is the 3 main caps in the middle, bolts, windage, oil pan and oil pick.
10. Pistons. You can use any b-series vtec piston in your ls block. Any 1.6 b-series piston will be raised by about one full point in the ls block like the b16a(pr3 pistons will raise it from the stock 10.2 comp in the b16a to 11.2ish in the ls block so keep this in mind when building the ls block. Also keep in mind about the combustion chamber size (See heads) when building the motor. . With a GSR, add .2 comp to the stock ratio. (Warning: these are all estimates: they could be off a little).
B16a head and pr3 pistons 11.2
B16a head and p30 pistons 11.4
B16a head and p72 (ao) pistons 9.9
B16a head and p72 (00) pistons 10.5
B16a head and p73 (ao) pistons 10.7
B16a head and p73 (00) pistons 11.2
B16a head and p61 pistons 10.4
B16a head and pct (CTR) pistons 12.2-3ish
B16a head and pr4 pistons 9.5
Add .2 to all to calculate the GSR head with all of these.
Type r and b17a heads have the same combustion chamber so calculates the same.
11. Conclusion. This information should help you get an idea of what it takes to build an LS/VTEC motor. As always, please, if you don’t know what you are doing, call a mechanic who can help you with anything
Old Oct 16, 2006 | 09:25 AM
tavius44's Avatar
Default Re: (4dOoR-Ex)
hey thanks for all the info it really help out alot and now i know what everything is thanks again
Old Oct 16, 2006 | 09:27 AM
b18sihatch's Avatar
b16!!!!
Old Oct 16, 2006 | 09:46 AM
philkehn's Avatar
Default Re: (JCrimson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCrimson &raquo;</TD></TR><TR><TD CLASS="quote">for the money, go b16 head
for great flow, go b17 head.</TD></TR></TABLE>
b16 flows better then the b17 and the b17 cost more then the b16, you dont make any sense
Old Oct 16, 2006 | 10:18 AM
b18sihatch's Avatar
Default Re: (philkehn)
and a port and polish b16 would flow even more (or get the itr) with the factory port and polish job
either way to get it done go with the b16
Old Oct 16, 2006 | 12:41 PM
you are wrong on the flow part
Old Oct 17, 2006 | 01:26 PM
philkehn's Avatar
okay
Old Oct 17, 2006 | 02:19 PM
russianswty's Avatar
https://honda-tech.com/zerothread?id=1767009
this shows you the differance between the gsr and the b16 heads.
Old Oct 17, 2006 | 02:51 PM
latinf86's Avatar
b16 head cause it the cheapest and u have more money left over to more put mods. but the type R is the best. its all on ur budged.
Old Oct 17, 2006 | 02:53 PM
latinf86's Avatar
Default Re: what head should I use for ls vtec? (latinf86)
i was going to do it myself but wen u get all the facts its just to much trouble and the brake down easy. i just dicided to just go all gsr. ur gonna end up with about the same horse power. and u can upgrade it just the same.
Old Oct 18, 2006 | 08:08 AM
philkehn's Avatar
Yea i hear they are not very realiable do to rod length and camshaft ratios differences from the block and the head
Old Oct 18, 2006 | 09:23 PM
ivanson's Avatar
bump''''
Old Oct 19, 2006 | 10:13 AM
philkehn's Avatar
Default Re: (ivanson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivanson &raquo;</TD></TR><TR><TD CLASS="quote">bump''''</TD></TR></TABLE>
Why are you bumping.....
Old Oct 19, 2006 | 11:50 AM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philkehn &raquo;</TD></TR><TR><TD CLASS="quote">Yea i hear they are not very realiable do to rod length and camshaft ratios differences from the block and the head</TD></TR></TABLE>
Do you also belive that Army Jets shot down UFOs because PBS told you so?
Old Oct 19, 2006 | 03:45 PM
project midnight's Avatar
Default Re: what head should I use for ls vtec? (Battle23)
**** if you got the money go for a mugen head!!!
Old Oct 19, 2006 | 03:46 PM
Ass$nyper's Avatar
Default Re: what head should I use for ls vtec? (bigj911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigj911 &raquo;</TD></TR><TR><TD CLASS="quote">**** if you got the money go for a mugen head!!! </TD></TR></TABLE>
holy crap frigging 06s...
Old Oct 19, 2006 | 04:02 PM
Default Re: what head should I use for ls vtec? (Capt. Blonde Beard)
whats that supposed to mean? Do they not make a mugen head for that ls?
Old Oct 19, 2006 | 05:59 PM
ivanson's Avatar
cuz i need da info...
bump it for it can go to recent topics..
im workin on a build...
