AFTERMARKET LOCKING NUTS... HELP
Old Oct 14, 2006 | 10:55 PM
hybridef's Avatar
Default AFTERMARKET LOCKING NUTS... HELP
heres the problem... bought a parts car, and all suspension and brake components as well as exhaust was not even a year old... it also came with 5 stars on it
now the problem is i didnt get a lock nut key with the car and the wheels... i took the front end apart, disconected the lower and upper control arms and what not and pulled everything off... i needed a caliper so i tried grinding the locking nut right down the middle... it worked except for a small chunk of metal that fused to the wheel and stud bolt
i ended up cutting each spoke on the wheel
now i want to preserve the rear hubs and rotors to do a rear brake swap on my 88
anyone suggest any ways to get these locking nuts off??
iv heard to weld a bolt to the nut and back it off... but do not have access to any welding equipment
iv also tried smashing a socket over it and also no luck
help would be appreciated
Old Oct 14, 2006 | 11:01 PM
r.wright's Avatar
Default Re: AFTERMARKET LOCKING NUTS... HELP (hybridef)
u can prolly also try an air wrench or get that master lug nut key set somewhere...maybe ebay.
Old Oct 14, 2006 | 11:14 PM
vtecsi00's Avatar
Default Re: AFTERMARKET LOCKING NUTS... HELP (mrrlx)
is it a gorilla lock or mcgard lock style????????
Old Oct 14, 2006 | 11:27 PM
hybridef's Avatar
Default Re: AFTERMARKET LOCKING NUTS... HELP (vtecsi00)
mcgard... canadian tire specials lol... i tried this lug nut remover, backwards threaded impact.. and all it did was slip.. so i guess there forged metal?
iv looked for master sets, and their near impossible to find for these aftermarket lock nuts
i also went back into canadian tire with a drawing and tried buying a set that looked like the key i needed
Old Oct 14, 2006 | 11:28 PM
vtecsi00's Avatar
is it the tuner style mcgard lock or the normal acorn style???????
Old Oct 14, 2006 | 11:33 PM
r.wright's Avatar
post a pic of the lug nut
Old Oct 14, 2006 | 11:38 PM
hybridef's Avatar
acorn style i suppose....... iv heard of them called cone style
heres a pic
Old Oct 14, 2006 | 11:57 PM
vtecsi00's Avatar
did you try using a 21mm socket and hammering it on and using an impact gun to take it off??????????
Old Oct 15, 2006 | 12:22 AM
r.wright's Avatar
^^^yup...that's what i did but cant remember the size i used for mine..
Old Oct 15, 2006 | 10:46 AM
hybridef's Avatar
and it worked on these exact lock nuts??
i tried bangin on a regular 1/2" socket.. and fucked the socket.... but havent tried bangin a impact socket on...
the one thng i was worried about was gettin the lock out of the sockett... i was just gonna use a vice and maybe the torch
Old Oct 15, 2006 | 10:52 AM
hybridef's Avatar
any other suggestions?
like i sad i cut right down the middle with the grinder of the one and stopped right before the stud... its hollow inside and was able to use a flat head punch and a hammer to break it away.. leaving a smal smal chunk that later after grinding some more, fused to the wheel and stud...
anyone try a different approach... i dont mind the labour on it.. id rather work at it longer to save the bucks on buying an impact socket and borrings the gun, and worry about it not working either.. iv already bought the impact lugnut remover for mangled lug nuts, and its useless to me really
Old Oct 15, 2006 | 04:02 PM
blub18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">did you try using a 21mm socket and hammering it on and using an impact gun to take it off??????????</TD></TR></TABLE>
try it TRUST IT WILL WORK i do it about 10x a day.. and if your scared go to a tire shop they have special sockets to get it off. 21 or 20mm i cant remember but try one of those that fit snugged. its very easy man.
Old Oct 15, 2006 | 04:06 PM
blub18's Avatar
Default Re: AFTERMARKET LOCKING NUTS... HELP (blub18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridef &raquo;</TD></TR><TR><TD CLASS="quote">and it worked on these exact lock nuts??
the one thng i was worried about was gettin the lock out of the sockett... i was just gonna use a vice and maybe the torch</TD></TR></TABLE>
to get the lock off the IMPACT 21mm socket all you do is bang the hell out of it VERY EASY trust me.
make sure its an impact because like you said it fucked up the other one becasue it wasnt impact. impact sockets are ment to take beaten there very strong.
L8ApexH22
Sep 19, 2014 05:49 PM
koolkevin1107
12
Nov 11, 2005 04:45 AM
user 996328629
Jun 5, 2004 05:53 PM
mstewar
Nov 13, 2003 09:23 AM
JDM_ITR
Sep 11, 2002 09:12 AM
