obd1 conversion help needed and WTF is this thing?
Old Oct 14, 2006 | 09:42 PM
mattcivic's Avatar
Default obd1 conversion help needed and WTF is this thing?
Im converting my 88 civic wagon to obd1. first off i noticed the bolt pattern on the dizzys was way off so i set the motor to TDC and made sure the rotor was pointing to the plug wire going to cylinder number 1. the car fired maybe 3 or 4 times but never actually started running then just spun over and over and never fired again. i got tired of messing with it so i put the obd0 dizzy back in and it fired right up.
heres the difference in the dizzys
heres the ob0 to obd1 jumpers i got from rywire
and one last thing WTF is this mounted next to the MAP sensor? can i get rid of it by just un hooking it and plugging off the vacume lines that go in and out of it?
Old Oct 14, 2006 | 10:37 PM
mattcivic's Avatar
Default Re: obd1 conversion help needed and WTF is this thing? (mattcivic)
Old Oct 14, 2006 | 11:30 PM
suspendedHatch's Avatar
You haven't given us nearly enough information. What head are you using? What computer are you using? You know that an OBD0 distributor is 16 teeth and an OBD1 is 24...
Don't bump your own thread after only one hour.
Old Oct 15, 2006 | 12:06 AM
jackinthetrunk's Avatar
Default Re: obd1 conversion help needed and WTF is this thing? (suspendedHatch)
you did not do enough research on what you wanted to do and now you are seating clueless. Search around or post clear details of what you are doing to what engine and with what ecu.
Ak_ef9's Avatar
what dizzy you use?
Old Oct 15, 2006 | 06:46 AM
shortyz21's Avatar
Default Re: obd1 conversion help needed and WTF is this thing? (Ak_ef9)
why the f.uck are you converting a d16 to odb1?
there is 0 reason to do this.
if its for ECU reasons, use turboedit or BRE..
edit: i see u wanna boost your wagon.. if your that set on ODB1 u gotta swap your head to a d16y7 or something with a bolt pattern of OBD1 for that distro to work...
i wouldnt even bother converting it, UBERdata isnt that much better then BRE...
Old Oct 15, 2006 | 09:13 AM
Rywire's Avatar
Default Re: obd1 conversion help needed and WTF is this thing? (shortyz21)
You need a td41 dizzy and obd1 ecu
Old Oct 15, 2006 | 09:28 AM
91' LS-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">You haven't given us nearly enough information.</TD></TR></TABLE>
More info on what Matt is going can be seen here: https://honda-tech.com/zerothread?id=1772949
Sorry I missed your call lastnight Matt, I was out of it.
What a\do you have so far, as for parts? What ecu /dizzy/ect.
Old Oct 15, 2006 | 09:44 AM
mattcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">why the f.uck are you converting a d16 to odb1?
i wouldnt even bother converting it, UBERdata isnt that much better then BRE... </TD></TR></TABLE>
the only reason im going obd1 is because my tuner does not deal with turbo edit. besides i had a spare obd1 ecu already chipped with crome and i picked up a single cam non vtec dizzy for free so i figured i scored. sorry if i may be asking stupid questions but i never work on single cams i have always had b's infact ive never owned an 88-91 civic anything that i have tried to mod ive always had cars that were 92-up so im not a newbie to hondas at all and i did search for this but everything i found was all on b series ****.
Old Oct 15, 2006 | 09:54 AM
jdmEF8racer's Avatar
well if you dont have one now then you should get a resistor box...and the is no reason to make it odb1 unless your gettin a obd1 motor...get a d16z6 head and use the stock harness wit the box and wire vtech wit the obdo dizzy...and get a p28 compyter wit a jumper cable...thatz the kind of setup i got and iam lovin it...good luck
Old Oct 15, 2006 | 09:56 AM
NikoZai's Avatar
Default Re: obd1 conversion help needed and WTF is this thing? (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">You need a td41 dizzy and obd1 ecu</TD></TR></TABLE>
OBD0 to OBD1 Instructions: http://www.rywire.com/store/im...r.gif
Also pay attention to what Oxygen sensor your new OBD1 ECU Requires. If it's 1-wire, you're set. If the ECU requires a 4-wire you'll have to change that as well.
Old Oct 15, 2006 | 10:00 AM
dr_latino999's Avatar
Default Re: (jdmEF8racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmEF8racer &raquo;</TD></TR><TR><TD CLASS="quote">well if you dont have one now then you should get a resistor box...and the is no reason to make it odb1 unless your gettin a obd1 motor...</TD></TR></TABLE> Going to OBD-1 just makes the world an easier place to deal with, especially since it opens up your possibilities on spare parts and electronics.
Old Oct 15, 2006 | 10:54 AM
mattcivic's Avatar
Default Re: (dr_latino999)
yes my car is already mpfi so i have a resistor box. expletive it im gunna go see if i can get the head that matches this dizzy today if not i will go see if my buddy wants to sell me a vtec head with the dizzy and just do a mini me swap.
NhoedeEJ1
Aug 20, 2012 01:40 PM
Faya
Engine Management and Tuning
Feb 16, 2009 07:40 PM
shaggyeg6si
Oct 6, 2008 09:14 AM
EnSAn
Jun 3, 2006 03:12 PM
650EF9HATCH
Feb 1, 2005 11:21 AM
