rod bearing keeps smashing
Old Oct 14, 2006 | 07:10 PM
Mugen112's Avatar
Default rod bearing keeps smashing
i have a gsr that i am replacing the rod bearings in. We go to torque the rod bolts to spec and then we try to move the crank shaft. Nothing happens. It just jams. We took the bearings out and on the edge of both bearings look smashed. The crankshaft journals look good though. Could it be that it just wasnt in there straight or what? I just wanted to ask before I go and screw up two more new perfectly good rod bearings... TIA
Old Oct 15, 2006 | 06:43 AM
F20Cteg's Avatar
Default Re: rod bearing keeps smashing (Mugen112)
You are using the wrong size bearings. I assume you have some aftermarket bearings and they are probably 25 over or even 50 over.
Get std size rod bearings.
Old Oct 15, 2006 | 04:18 PM
Mugen112's Avatar
we compared them and there actually wider. would that make any sence at all? do they sell wider bearings? i thought for bigger bearings they just made them thicker, not wider.
Old Oct 15, 2006 | 08:53 PM
Scott_Tucker's Avatar
Default Re: (Mugen112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen112 &raquo;</TD></TR><TR><TD CLASS="quote">we compared them and there actually wider. would that make any sence at all? do they sell wider bearings? i thought for bigger bearings they just made them thicker, not wider.</TD></TR></TABLE>
Yeah, those are the wrong bearings. Because the bearing is wider the edges are cutting in the filets on the crankshaft.
Old Oct 16, 2006 | 01:59 PM
91SiZ6's Avatar
Get the correct bearings and Plastigage them to check for clearances instead of just rotating the crankshaft.
Old Oct 17, 2006 | 08:41 AM
Mugen112's Avatar
If the plastigauge shows the bearings are too loose, can I just tighten the rod bolts down tighter to get the clearances closer? I know your supposed to buy thicker bearings, but is it possible to do it the ghetto way?
Old Oct 17, 2006 | 10:37 AM
91SiZ6's Avatar
Yeah, you can do it the ghetto way. But you'll be rebuilding your block in a few thousand miles. One of the mottos I live by is this, "anything worth doing, is worth doing correctly the first time."
Old Oct 17, 2006 | 05:27 PM
Dogginator's Avatar
Daisy... Daisy...
If I recall correctly, he B18C GSR engine has narrower rod bearings than the B18A or B. What bearings do you have?
Old Oct 17, 2006 | 05:53 PM
F20Cteg's Avatar
Default Re: rod bearing keeps smashing (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">If I recall correctly, he B18C GSR engine has narrower rod bearings than the B18A or B. What bearings do you have?</TD></TR></TABLE>
I would like to clear that up too.
I have used some rod bearings on a D16 that said on the box "D16, B18 A/B/C"
Honda definitely has different parts numbers for GSR, D16, and B18A/B.
I think I have some old OEM GSR bearings at home, also OEM LS's. I'll check widths and report back.
&gt;&gt;&gt;&lt;&lt;&lt;
Old Oct 17, 2006 | 11:47 PM
eg:R's Avatar
ls rod bearing are a bit wider than gsr
Old Oct 18, 2006 | 11:52 AM
HiProfile's Avatar
Default Re: (eg:R)
http://www.raceseek.com/honda_specs.htm
Look at 'BEW', C1/C5 have the narrowest rods. There's a chance they could even be D16 rod bearings, assuming they look almost the same width - d16s and b-series rod bearing diameters are the same.
aliabdeen
Motorcycles
Nov 21, 2017 07:42 PM
Charlie Moua
Jan 16, 2012 07:01 PM
dj-t
Jul 2, 2009 08:48 AM
Baron55
Aug 28, 2006 12:37 PM
