Change motor harness and now car is acting up
Old Oct 14, 2006 | 03:10 PM
dblock's Avatar
Default Change motor harness and now car is acting up
i have a 93 civic cx with a b18c1. i changed the motor harness to a gsr motor harness but now the car is idiling funny and the motor is choppy (shaking in a weird manner) . everything is plugged in correct . im also throwing a code 16 (bad fuel injector it says) but i changed them and its still the same. what could be the problem?
Old Oct 14, 2006 | 03:13 PM
md88hfcrx's Avatar
Default Re: Change motor harness and now car is acting up (dblock)
why not switch back to original harness?
Old Oct 14, 2006 | 03:15 PM
dblock's Avatar
it was fried so i had to change it.
Old Oct 14, 2006 | 03:22 PM
md88hfcrx's Avatar
Default Re: (dblock)
oh. heres how i would check:
while car is running, remove each plug wire one at a time. if you remove one and it doesnt change the idle, troubleshoot that individual injector wire by checking the continuity from the ecu. just an idea.
Old Oct 14, 2006 | 03:26 PM
dblock's Avatar
the fourth plug furthest from the battery does not change the idle.
Modified by dblock at 12:40 AM 10/15/2006
Old Oct 14, 2006 | 04:03 PM
dblock's Avatar
Old Oct 14, 2006 | 04:06 PM
philosofy1's Avatar
did you ground out the injectors in a good spot? there is a ground wire for them, if it's not grounded right it'll act up.
Old Oct 14, 2006 | 04:25 PM
dblock's Avatar
wheres the ground?
Ken Lam
Jan 22, 2017 08:38 AM
H23_del_soul
Aug 26, 2010 04:30 PM
spiderhatch
Apr 15, 2007 02:33 PM
SpoolinEK9
Jan 9, 2005 11:33 AM
ScottFern
Aug 16, 2002 12:21 PM
