Trans leak
just wondering if b series trannys have any common leak spots? my gsr trans was popping out of fifth and i found that it only had like half a quart of motor oil in it, so i flushed that out and filled it with syncromesh and now its good but i can still smell the leak(falls onto header and burns off). So yeah where should i check? i cant seem to find the leak, and i want her ready for the next street legals in fontana. Thanks
You know what, spray it down with a light application of water and then drive it around for a day or two and check it again, and obviously keep an eye on the fluid level. I think you should be able to find a leak if there is one, so it probably is some leftover fluid.
