F22A1 vs F23A5
Old Oct 14, 2006 | 08:36 AM
Rishiras's Avatar
Default F22A1 vs F23A5
Guys,
A friend of mine with prelude 95 with F22A1 has a head problem.
since head is hard to find, we wanna swap a F23A5 Accord SOHC 98 engine into this car.
Any suggestions regarding fitment, ecu, harnass, distributor we should now before we swap this.
Rishi
Old Oct 14, 2006 | 11:15 AM
BlUAc's Avatar
Default Re: F22A1 vs F23A5 (Rishiras)
it should be able to bolt on I say keep the dist and get an ecu the ex mani wont fit I believe. and I question a water pipe in the back of the head to the im but a lil mod can fix that
Old Oct 14, 2006 | 11:28 AM
All-Motor-Junkie's Avatar
^^+1, all you should need is an ecu and ex mani like said
Old Oct 14, 2006 | 05:08 PM
v4lu3s's Avatar
RTFM
you will need to use teh f23 intake and exhaust manifolds for sure, and then also probably do some sort of custom extension from teh header to exhaust as well.
Old Oct 14, 2006 | 05:16 PM
darkspector2.0's Avatar
just wondering... why this motor.. why not an h22??
Old Oct 14, 2006 | 05:47 PM
Rishiras's Avatar
Default Re: (darkspector2.0)
Ok, the thing is like this.
We imported a SOHC CIVIC 95 VTEC engine from hondaspecialist in Miami, to Curacao, Island next to Aruba.
Hondaspecialist send a Honda accord 98 F23A5 engine instead, which give us a lof of problems, since this was not what was asked for the Civic.
Now a other friend with Prelude 95 has a head problem, and since Fseries, we are thinking to sell him this Acord engine, since its here for nothing.
I assume we need then also a conversion ECU cable for obd1 to obd2a?
rest of parts we will buy are then>distributor Accord F23A5
The Ex manifold is on the engine.
Old Oct 15, 2006 | 03:48 PM
v4lu3s's Avatar
RTFM
he hsould run the 94-95 accord ex ecu to make it easiest thoug he may need to bump fuel pressure up slightly with it. i would also use the 94-95 accord ex distributor as well.
Old Nov 3, 2010 | 01:19 PM
ttblk1's Avatar
i am doing this same swap and the motor came with no motor mounts do you guys know where the rear motor mount goes on the rear of the motor.
FNHondaGuy21
May 1, 2019 07:12 PM
89a6T
May 30, 2006 12:59 PM
arc
Nov 27, 2005 11:54 AM
iloseinterest
May 27, 2005 04:40 PM
Passaudi1.8t
Apr 24, 2002 08:08 AM
