Car wont start
Old Oct 14, 2006 | 08:24 AM
tmramsburg's Avatar
Default Car wont start
I have a 2000 stock cx. When I would go wide open throttle it would missfire. Changed plugs, wires, rotor, cap. Still missed. Then i replaced the distributor and battery. Now it wont start. Every 5 seconds of cranking i get a pop or a thud, sounds like it wants to start. The starter sounds funny too, cant explain. Im getting tired of diagnosing it.
any help would greatly appreciated!!!!
Old Oct 14, 2006 | 08:49 AM
DXH's Avatar
DXH
Default Re: Car wont start (tmramsburg)
im not no expert really about that cause it seems you changed most the things i would suggest, but did you change the coil? im guessing so but if you have a thud or a pop maybe it might by your valves or a piston make sure your plugs are gapped right.. but when you ran a diognostic on it what did it say just mis firing cylinders?
Old Oct 14, 2006 | 09:05 AM
tmramsburg's Avatar
before i bought the plugs, wires, ect.. cylinder 1,3,4 misfired
Old Oct 14, 2006 | 09:13 AM
DXH's Avatar
DXH
Default Re: (tmramsburg)
i actually might have just saved your day.. now that i think of it i had a 99 honda EX and i kept getting misfiring cylinders and i replaced everything you did.. after i sold that car cause it was givin me problems my auto teacher said that clogged or plugged catalitic converters or resinators can send exhuast back up or something like that so i am pretty sure thats what it is.. if its makin popping noise your cat is probably really really clogged.. try that or check it out im pretty sure that could be part or most of the cause
Old Oct 14, 2006 | 10:01 AM
tmramsburg's Avatar
still nothing
Old Oct 14, 2006 | 10:24 AM
DXH's Avatar
DXH
did you take it off? or how did you tell it was plugged? if you did reset your ecu unplug your batt. then turn it back on
Old Oct 14, 2006 | 11:34 AM
tmramsburg's Avatar
alredy reset ecu. unbolted and removed manifold
Old Oct 14, 2006 | 11:45 AM
4dohs4mohoes's Avatar
Make sure you have the firing order correct.
Old Oct 14, 2006 | 02:32 PM
tmramsburg's Avatar
1,2,4,3 ccw
teamTakeo
Aug 20, 2023 07:58 PM
egbarteezy
Apr 5, 2011 05:01 PM
JohnnyWash1
40
Mar 24, 2009 01:30 PM
lilgreenlude93
Apr 7, 2004 10:20 PM
JDMH22HATCH
23
Mar 7, 2003 12:36 AM
