CHECK ENG LIGHT
Old Oct 14, 2006 | 05:31 AM
jerry05's Avatar
Default CHECK ENG LIGHT
I have a 2000 1.8 ls non v-tec with a check eng light that keeps coming up for misfire on all 4 cyl. I have checked everything I can think of and yet after 5 to 10 miles it keeps coming back.
I put in an msd dist, new plugs, wires, cap rotor, and reste the timing.
Any ideas?
Old Oct 14, 2006 | 07:32 AM
Chiovnidca's Avatar
Default Re: CHECK ENG LIGHT (jerry05)
Does the cel flash while driving? Have you checked the fuel pressure? Any water in the gas? Valves adjusted too tight?
Old Oct 14, 2006 | 08:36 AM
jerry05's Avatar
valves are fine no water in gas. it does flash while driving and then goes soild. i never thought about fuel pressure. i will check that, thanks.
Old Oct 14, 2006 | 12:47 PM
Chiovnidca's Avatar
Default Re: (jerry05)
A flashing cel indicates a pretty bad missfire. I've never seen one code all 4 cylinders with a flashing light.
Any mods done to the engine? Is it a swap? What ecu? Has it been tuned?
Old Oct 14, 2006 | 01:20 PM
jerry05's Avatar
new ecu 2 months ago(factory)
header,venom 400, cat back exhaust, msd ignition, skunk2 intake, and 72 mm throttle body.
it started about three months after all the upgrades with bad cam sensor so i replaced the dist. after that i started to get the misfire code. car runs great, that is why i can not figure this out.
Old Oct 14, 2006 | 02:00 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerry05 &raquo;</TD></TR><TR><TD CLASS="quote"> replaced the dist. after that i started to get the misfire code. </TD></TR></TABLE>
Something with the distributor maybe?
Old Oct 14, 2006 | 07:15 PM
GoldenEGG's Avatar
Default Re: CHECK ENG LIGHT (Chiovnidca)
what kind of wires u got? I had the same problem on my LS.V tec.. I had Nology Hotwires on till i bought NGK Blue wires and all misfireing codes were gone.
91accordflow
Jun 6, 2009 05:12 PM
civ05se
Honda Civic (2001 - 2005)
16
Jun 21, 2008 11:21 AM
freddysEF
43
Jan 29, 2008 12:41 PM
david90
Jul 29, 2003 05:40 PM
SuPeRITR
Mar 18, 2003 06:02 PM
