Swaybar endlink question
Old Oct 14, 2006 | 03:36 AM
De_tour's Avatar
Default Swaybar endlink question
Modified by De_tour at 4:38 AM 1/9/2007
Old Oct 14, 2006 | 04:03 AM
Sleepy_Red_hatch's Avatar
Default Re: Swaybar endlink question (wspcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wspcivic &raquo;</TD></TR><TR><TD CLASS="quote">I was changing out some LCA's and decided to flip the angle bracket to have a little more clearance for the sway bar. When i bolted it back up it was a pretty stiff fit and when i drove the car it felt way more responsive in corners then when i had the bracket faced the other way.
Suspension Tech Swaybar on 92-95 civic
Should having the endlinks raised up make it harder for the sway bar to flex when in a corner or bump? and would this resistance cause any problems or harm to the subframe or other suspension components?
you're preloading the swaybar, it has less flex now...is that good or bad? i dont know
Old Oct 14, 2006 | 06:02 PM
De_tour's Avatar
Default Re: Swaybar endlink question (Sleepy_Red_hatch)
Bump
Old Oct 14, 2006 | 06:11 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
post this in the suspension forum, they should be able to tell u
Old Oct 14, 2006 | 06:44 PM
De_tour's Avatar
bump noone has awnsered over in suspension forum
Old Oct 14, 2006 | 07:49 PM
De_tour's Avatar
bumpp
Old Oct 15, 2006 | 03:40 AM
De_tour's Avatar
bumppp
Old Oct 15, 2006 | 03:55 AM
GarageAlchemist
Guest
Posts: n/a
whatever works better man.. i'd get a aspec or you're own custom subframe plate just incase..
Old Oct 15, 2006 | 03:56 AM
De_tour's Avatar
Default Re: Swaybar endlink question (GarageAlchemist)
so dont preload it till i get the ASR brace?
Old Oct 15, 2006 | 04:02 AM
FuNkDrSpOt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">you're preloading the swaybar, it has less flex now...is that good or bad? i dont know</TD></TR></TABLE>
Co-sign, except we'd need to know the size of the swaybar to know if it's good or bad. If your using 18mm ( and I can only go off what I know from my '97 subframe being weak as hell ) Then you'll probably want to invest in the ASR brace. You're essentially placing a similar amount of stress on the subframe as if you were rounding a corner ( at whatever speed & angle that causes the swaybar to bend @ that angle ) except you're doing it all the time.
Old Oct 15, 2006 | 04:08 AM
Yodastien's Avatar
what rims are you rockin are they slips or soons
Swipe'd
Mar 22, 2014 07:59 AM
kefka
Aug 10, 2004 04:50 AM
"Fresh Pizza Guy"
May 25, 2004 04:26 PM
