Audio Harness color coding
Radio 12v white/blue +
Radio Ground black -
Radio Ignition yellow/red +
Radio Illumination red/black +
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- blue/green - gray/black +,-
RF Speaker +/- red/green - brown/black +,-
LR Speaker +/- blue/yellow - gray/white +,-
RR Speaker +/- red/yellow - brown/white +,-
Hope this helps.
Power Antenna N/A
Hope this helps.
which of the wires on the harness needs to be connected to the corresponding wire on the after market harness to keep the memory? (shut the car off, turn it back on and it "remembers" what track you were on last)
horrible wording...i know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STDClayton »</TD></TR><TR><TD CLASS="quote">which of the wires on the harness needs to be connected to the corresponding wire on the after market harness to keep the memory? (shut the car off, turn it back on and it "remembers" what track you were on last)
horrible wording...i know.</TD></TR></TABLE>
Should be the yellow wire on the aftermarket harness
yellow wire from the aftermarket harness to the white/blue on the cars harness. Or you can run it directly to the battery if you have a fuse holder. Use a 10~15A fuse in the fuse holder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_DC4 »</TD></TR><TR><TD CLASS="quote">yellow wire from the aftermarket harness to the white/blue on the cars harness. Or you can run it directly to the battery if you have a fuse holder. Use a 10~15A fuse in the fuse holder.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marquisdee1018 »</TD></TR><TR><TD CLASS="quote">
Should be the yellow wire on the aftermarket harness</TD></TR></TABLE>
thanks dudes!
thanks dudes!
ilikejesus
Audio / Security / Video
Jun 15, 2007 05:01 PM
Sherm
Sep 23, 2006 12:07 PM
Ratchback
Aug 24, 2004 08:11 PM
