Slowest B18C EG
Old Oct 13, 2006 | 07:26 PM
eg6madness's Avatar
Default Slowest B18C EG
i swapped a B18C in my EG and oh my god it is slow. dont get me wrong it is faster than the D15B which i had in but it is not as fast as B16 Civics.
i was coming home just now and a Honda YRV some **** passed me (I wasnt racing him but still, dude got the ***** to pass me ). I am pissed off.
Here are the specs:-
JDM B18C
Fuel pressure regulator ( no gauge tho)
the motor suppose to have a ITR exhaust cam
it has the S80 LSD gearbox.
Cold Air intake
all of this is in a EG hatch
What can i do with the motor as is to make it up to par with other GSR motors with similar setup ?
What distributor timing is run on these motors?
What plugs should i run ? ( i have NGK 6s in the motor)
i want the motor to pull hard as it is so i can start building form that platform and then just improve.
What must i do to be up there now?
Old Oct 13, 2006 | 08:26 PM
si937's Avatar
Get it to a dyno with a tuner. Im sure something is wrong. I also had a slow gsr but i was more then sure it was tuning.
Old Oct 13, 2006 | 10:51 PM
chuniepatuni's Avatar
what ecu are u running?
Old Oct 14, 2006 | 12:47 AM
eg6madness's Avatar
Default Re: (chuniepatuni)
stock p72
Old Oct 15, 2006 | 06:14 PM
daver's Avatar
Default Re: (eg6madness)
are you using the stock exhaust?
Old Oct 15, 2006 | 07:07 PM
maxspeedhonda's Avatar
Default Re: (daver)
smoke of any kind?
Old Oct 15, 2006 | 10:51 PM
sitinthehall's Avatar
Default Re: (maxspeedhonda)
You should get a fuel pressure guage, I did that then upped the psi 5-10 higher than it was supposed to be. After that it ran a lot smoother and was noticably faster.
Old Oct 16, 2006 | 06:49 AM
inline4's Avatar
Default Re: Slowest B18C EG (eg6madness)
don't feel bad. my gsr eh hatch only traps a measly 90mph in the quarter mile and runs mid 15's. somethings wrong with mine too. it's pretty much a bolt ons motor, no tuning and stock p72. horse power calculator estimates it has like 125 to the wheels.. that's just *** for a GSR motor.
Old Oct 17, 2006 | 01:06 PM
eg6madness's Avatar
Default Re: (sitinthehall)
i just got my fuel pressure gauge and installed it. the car was set at aroun 27psi, would you believe that. well i set it not to around 50psi. didnt go out and carry it for a drive yet but i can hear the difference when it starts. no more lumpiness, just a smoth turn over and idle. i'll let you guys know what is going on with it later
MrHonda10
Aug 7, 2018 04:07 PM
eg6madness
Oct 15, 2006 07:55 AM
athbaseball23
10
Jun 7, 2006 11:14 AM
ted
Jun 24, 2005 01:15 PM
Mister Fixer
Jun 1, 2003 09:38 AM
