1989 Honda CRX Si with BAR'd B16, 562 area
Old Oct 13, 2006 | 04:39 PM
fourthgenhatchB17's Avatar
Default 1989 Honda CRX Si with BAR'd B16, 562 area
CAR HAS OFFICALLY BEEN SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!
PRICE: SOLD If you dont like it, I dont care. Please dont post in my thread saying anything negative. Posts will be reported if it gets out of hand. I am in absolutely NO rush to sell. I love driving this car .
General Info:
VIN JHMED936XKS008532
Clean title
207,xxx miles on the chassis
BAR'd motorswap (100% smog legal in California)
Ive managed to get 30+ MPG as it sits now!
I'd describe it as a "daily driver."
I have some receipts in a folder but most parts were bought second hand (no receipts).
I performed ALL the engine work/swap/and wiring/some cosmetic stuff and the checking of the parts listed below.
Can include a CD with all the pics Ive taken during the motor swap process as well as the wire tuck. This way you know exactly how it was done and be able to see the quality!
Exterior:
Repsprayed by previous owner (have receipt), average quality.
No major dents, just a few small door dings here and there.
90-91 Tail lights.
Front bumper grill cut out (done by previous owner).
OEM corner lights and bumper lenses.
Sunroof opens and closes just fine.
Will come with 14" Integra LS mesh with matching Kuhmo's and lots of tread left. (see pic).
Interior:
Pretty much stock, 100% complete!
OEM floormats in good condition.
Driver side seat a bit worn (pretty typical), no huge *** holes or rips though, lol.
Shift **** will be a type R one.
Eclipse CD player (retails for $250 online)...will get model number soon.
Pioneer speakers front and rear.
Pioneer 10" sub.
MTX amplifier.
Suspension:
Tokico Illuminas with Skunk2 coil overs.
ES top hat bushings.
New steering rack boots.
New steering rack end bushing.
New front wheel bearings.
Recently replaced right rear hub/bearing assembly.
Inner and outer tie rods/upper and lower ball joints have all been checked (OK).
Front TOE has been set (could use a 4 wheel align., no funny tire wear issues).
Original SI front and rear sway bars.
Front strut tower bar.
Braking:
New front pads and rotors.
New rear shoes.
Flushed brake fluid.
M/C, rear wheel cylinders, calipers have been checked (OK).
Under the Hood:
BAR'd First gen JDM B16A (unknown actual mileage). No smoke, runs puuuurrfect!
P30 intake manifold, throttle cable and matching bracket (no rigged **** here, lol)
Oil and filter was just changed (HAMP filter used)
New fuel filter.
99 SI fuel rail (bling!)
DC header.
2 1/4" exhaust piping with NEW Magnaflow cat, unknown brand resonator and stock style muffler (sounds 100% like a stock CRX when driven normally)
Accel spark plug wires.
NGK plugs.
Restored valve cover ( ).
Valve adjustment just performed.
NEW OEM Honda front main seal, rear main seal, cam seals, water pump, dizzy o ring, intake manifold gasket, throttle body gasket.
NEW OEM Honda oil pan gasket (still seems to weep a little from pan gasket area)
Gates brand timing belt.
'95 GSR throttle body.
AEM short ram intake, K&N was just cleaned (will include cold air extension).
Distributor has recently been changed for a new unit.
All metal radiator.
Y1 LSD tranny (NO GRINDS!) with Exedy stg 1 clutch and ACT street lite flywheel.
New genuine Honda MTF tranny fluid.
Axles look original to the swap, but show no signs of wear.
Hasport mounts.
AZ Race shift linkage.
No name short shifter.
Wire tuck.
P28 with stock Kenji P30 chip. Will also include a Kenji "street" and "race" chip.
Will be sold with these rims and tires!
Modified by fourthgenhatchB17 at 9:22 PM 10/15/2006
Modified by fourthgenhatchB17 at 9:25 PM 10/15/2006
Modified by fourthgenhatchB17 at 8:55 PM 10/21/2006
Old Oct 13, 2006 | 06:19 PM
crx2nr822's Avatar
Default Re: 1989 Honda CRX Si with BAR'd B16, 562 area (fourthgenhatchB17)
Do u still have your hatch??? Damn this is a clean *** crx! mad props to you my friend, hopefully we'll meet again at another EF meet
Old Oct 13, 2006 | 06:25 PM
mr_nemesis2003's Avatar
Clean car, if i don't sell mine, i want it to look your yours.
Old Oct 13, 2006 | 06:40 PM
Wes V's Avatar
Default Re: (mr_nemesis2003)
<U>Just a quick "thumbs up" for the quality of work that Erik does!!</U>
It should also be pointed out in big letters that the engine conversion has been through the referee process and is legal. No fears of the cops pulling you over (at least not in regards to the legality of the car).
Ya, Erik's a friend, but he is also one of the few people I'd trust to work on my car.
Wes Vann
Old Oct 13, 2006 | 06:47 PM
boostnhoe's Avatar
Nice CRX Price is pretty much on target.... Good luck with your sale
Old Oct 13, 2006 | 08:00 PM
xyzalvarez's Avatar
Default Re: 1989 Honda CRX Si with BAR'd B16, 562 area (boostnhoe)
bump this
Old Oct 13, 2006 | 09:20 PM
Default Re: 1989 Honda CRX Si with BAR'd B16, 562 area (crx2nr822)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2nr822 &raquo;</TD></TR><TR><TD CLASS="quote">Do u still have your hatch??? Damn this is a clean *** crx! mad props to you my friend, hopefully we'll meet again at another EF meet </TD></TR></TABLE>
Yup still have the hatchback! Shes not going anywhere .
For sure man
As for everyone else, thanks for the kind words.
I want this CRX to go to a good home!
Old Oct 15, 2006 | 12:38 PM
pandarex's Avatar
that is a good deal, bump it up
Old Oct 15, 2006 | 12:45 PM
lunchboxEF91's Avatar
Erik knows his stuff. A well worthy pick up. Free bump
Old Oct 15, 2006 | 05:30 PM
Pvong's Avatar
pm'ed
Old Oct 15, 2006 | 06:08 PM
Default Re: 1989 Honda CRX Si with BAR'd B16, 562 area (pandarex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pandarex &raquo;</TD></TR><TR><TD CLASS="quote">that is a good deal, bump it up</TD></TR></TABLE>
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lunchboxEF91 &raquo;</TD></TR><TR><TD CLASS="quote">Erik knows his stuff. A well worthy pick up. Free bump</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pvong &raquo;</TD></TR><TR><TD CLASS="quote">pm'ed</TD></TR></TABLE>
Replied.
Old Oct 15, 2006 | 06:13 PM
HondaBondMan's Avatar
B A N N E D
Bump....that is a clean CRX...
Old Oct 15, 2006 | 10:09 PM
LERRY's Avatar
bump for a very clean crx
Old Oct 15, 2006 | 10:29 PM
eg6sir-s's Avatar
clean!
Old Oct 16, 2006 | 11:27 AM
Default Re: 1989 Honda CRX Si with BAR'd B16, 562 area (eg6sir-s)
Thanks fellas!
Old Oct 16, 2006 | 11:49 AM
TrueUntilDeath.com's Avatar
for a second there i thought you sold the EF!
Old Oct 16, 2006 | 12:11 PM
nihkon's Avatar
Default Re: (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">Ya, Erik's a friend, but he is also one of the few people I'd trust to work on my car.</TD></TR></TABLE>
You said it brutha!
So sad to see it go man.
Old Oct 16, 2006 | 12:39 PM
cheeksnme's Avatar
Default Re: (nihkon)
is it sold?
Old Oct 16, 2006 | 12:53 PM
gsrboosten's Avatar
bump ! i wish i had 1k more to buy ur car
Old Oct 16, 2006 | 05:58 PM
Default Re: (cheeksnme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheeksnme &raquo;</TD></TR><TR><TD CLASS="quote">is it sold?</TD></TR></TABLE>
Should be unless the perspective buyer doesnt care about his deposit, lol. Non refundable...so i doubt he'll back out.
Old Oct 16, 2006 | 06:03 PM
xyzalvarez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">
Should be unless the perspective buyer doesnt care about his deposit, lol. Non refundable...so i doubt he'll back out.</TD></TR></TABLE>
hoo man, so its sold! yeah...it wont last to much......not too crazy but still OEM look.nice color, nice body..and bar'd... ..
BTW..i would love to have my third crx..
Old Oct 16, 2006 | 06:09 PM
Default Re: (xyzalvarez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xyzalvarez &raquo;</TD></TR><TR><TD CLASS="quote">
Yup. I mean how often do u see stock corner lights? Usually its cheapo clear deals that leak water, lol. You can never go wrong with the OEM/stock look. Its usually a winner every time.
Old Oct 18, 2006 | 10:41 PM
STREETWERKZ's Avatar
wow, nice.
Old Oct 21, 2006 | 12:10 AM
efrex's Avatar
Default Re: (STREETWERKZ)
bump...nice rex
Old Oct 21, 2006 | 11:22 PM
nihkon's Avatar
Default Re: (efrex)
Saw it today for the last time. So sad.
lol.
