TB coolant bypass idle issue
Old Oct 13, 2006 | 04:22 PM
kornerk12's Avatar
Default TB coolant bypass idle issue
I did it today but left the FITV alone and just looped the lines on the IACV and block and I had horrible idle issues which became even worse with a load on the engine. This is after the engine was warm. Has anyone else done this on the H22 ?
Old Oct 13, 2006 | 04:48 PM
98vtec's Avatar
moderator emeritus
Default Re: TB coolant bypass idle issue (kornerk12)
did you plug the FITV ends?
my car idles perfectly
Coolant looped at the thermo. IACV looped. FITV plugged.
Old Oct 13, 2006 | 07:32 PM
TheWalrus's Avatar
if the car stumbles under load its gotta be a vacuum leak. if the idle is just fluctuating, play with the idle adjustment screw...i had that problem and turning the screw in a bit helped the surging at idle when warm
Old Oct 14, 2006 | 07:35 AM
kornerk12's Avatar
Default Re: TB coolant bypass idle issue (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">did you plug the FITV ends?
Coolant looped at the thermo. IACV looped. FITV plugged.</TD></TR></TABLE>
Nope. What did u plug them with ? Is there anyway to just eliminate it and run a plate under the TB ? Or because of the sensor there will it trip a CEL ?
Old Oct 14, 2006 | 08:14 AM
fastludeh22's Avatar
back when i had all that stuff. i looped the lines on each, to themselves..never had any problems
Old Oct 14, 2006 | 08:16 AM
Default Re: TB coolant bypass idle issue (fastludeh22)
sorry to theard jack, but side question. isnt the line coming out of the thrmo housing where you will find the coolest water? since its coming directly from the rad.
Old Oct 14, 2006 | 09:18 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">sorry to theard jack, but side question. isnt the line coming out of the thrmo housing where you will find the coolest water? since its coming directly from the rad. </TD></TR></TABLE>
That coolant is actually coming up the water pipe from the water pump...
Old Oct 14, 2006 | 10:05 AM
tacticalcustoms's Avatar
Default Re: TB coolant bypass idle issue (Hawkze_2.3)
I did this the other day and had idle problems. so I just put everything back to normal. and I did loop all the plugs and I did plug up the FITV. but who knows. I know I did it right
Old Oct 14, 2006 | 10:08 AM
prelude1897's Avatar
Default Re: TB coolant bypass idle issue (tacticalcustoms)
I did the coolant bypass a few months back and things were fine, but now I have some pretty bad idle issues. Damn, I wish I remembered how everything was done so I can reverse this
Old Oct 14, 2006 | 11:41 AM
kornerk12's Avatar
Default Re: TB coolant bypass idle issue (prelude1897)
Hmm thats weird ?
Old Oct 15, 2006 | 06:45 AM
Duane_in_Japan's Avatar
Make damn sure there is no air in the cooling system, NONE.
Old Oct 16, 2006 | 06:31 AM
kornerk12's Avatar
Default Re: TB coolant bypass idle issue (Duane_in_Japan)
Well i dont think there is any air in the system. And i looped the line from the TB to the FITV, IAVC to itself and block to thermo and had major idle issues. But i didnt plug the FITV i just ran a hose from the TB to the FITV.
Old Oct 16, 2006 | 07:27 AM
OK, its time to start putting your finger over air holes to troubleshoot, pull the air induction hose off of the throttle body and cover one air bleed hole at a time, I think there are two. Also take the cover off of the wax pellet where you could use a screwdriver to adjust it closed and cover that with a rag to see if the idle cures itself.
If the idle cleans up when you block off one of these three air bleeds then you have found your problem. It is possible to have a vacuum leak or the throttle body plate be open too far.
There are other possiblities also.
footstinker
Nov 6, 2010 01:09 AM
SHG_EasyE
Apr 2, 2006 08:10 PM
Wicked Sol
Mar 6, 2003 05:49 AM
LsTurbo91
Dec 18, 2001 12:23 AM
