Hatch Defroster Problem
Old Oct 13, 2006 | 03:30 PM
psyloki's Avatar
Default Hatch Defroster Problem
Hello,
My hatch defroster is only working in two of the bars. Is there a kit i can buy to put new strips on the window? Or is there a better option?
Opinions and Constructive Ideas Please.
Thank You
-Ted
Old Oct 13, 2006 | 04:52 PM
babyhoohey's Avatar
Default Re: Hatch Defroster Problem (psyloki)
there is actually a fluid made for your very situation. You mask around the bar going across the window, and you apply this fluid after a thorough cleaning (applied like white out, a metallic looking solution), in two thin coats. It should restore proper defroster operation if applied correctly, and there is no circuit malfunction.
Old Oct 13, 2006 | 08:30 PM
Tippyman's Avatar
Default Re: Hatch Defroster Problem (babyhoohey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by babyhoohey &raquo;</TD></TR><TR><TD CLASS="quote">there is actually a fluid made for your very situation. You mask around the bar going across the window, and you apply this fluid after a thorough cleaning (applied like white out, a metallic looking solution), in two thin coats. It should restore proper defroster operation if applied correctly, and there is no circuit malfunction.</TD></TR></TABLE>
Link? My defroster only works about half-way...
Old Oct 13, 2006 | 11:32 PM
CRXDaddy78155's Avatar
Ok so..........do you know what the name of this "FLUID" is or where it's available?
Old Oct 14, 2006 | 10:25 AM
Tippyman's Avatar
Default Re: Hatch Defroster Problem (88DXREX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXREX &raquo;</TD></TR><TR><TD CLASS="quote">
Ok so..........do you know what the name of this "FLUID" is or where it's available? </TD></TR></TABLE>
Yes, that would be very helpful.
Old Oct 14, 2006 | 12:58 PM
marquisdee1018's Avatar
I'd also like to know about this fluid.
Old Oct 14, 2006 | 08:59 PM
Tippyman's Avatar
BUMP 4 FLuid! Lolz...
Old Oct 15, 2006 | 01:39 PM
Default Re: (Tippyman)
Bump.....Doesn't anyone have any info on this Mysterious "Fluid" ?
Old Oct 15, 2006 | 02:42 PM
Tippyman's Avatar
BUMP!!!
Old Oct 15, 2006 | 07:57 PM
sporkcrx's Avatar
I've seen the stuff as well, at your general auto part stores. No idea what the name is. Maybe I'll look next time I'm there.
Old Oct 16, 2006 | 05:03 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">BUMP!!!</TD></TR></TABLE>
Old Oct 16, 2006 | 05:07 PM
I CRX I's Avatar
This kit looks promising http://www.frostfighter.com/ff_pdt_2100.htm
Old Oct 16, 2006 | 05:09 PM
I CRX I's Avatar
&lt;----Striped my bars trying to remove POS tints from rear window :-\
Old Oct 16, 2006 | 05:14 PM
Tippyman's Avatar
Cool.
TooManyTickets
30
Jul 16, 2007 09:45 PM
hxtasy
Aug 31, 2005 06:05 PM
Cuong-nutz
Dec 8, 2004 05:50 PM
Tench
Jun 5, 2004 10:46 AM
EK4civichatch
14
Nov 12, 2003 05:57 PM
