cam gears..which ones is good?
i want to install cam gears..i which one should i get..dc sport or aem or skunk2? i heard they are easy to install but you have to cut to fit so maybe its better to have them installed....should i get pullys at the same time..b4 i tune,
thanks
thanks
cam gears..which ones is (ARE) good?
You want ones that will not slip. So generally the more bolts the better.
Nothing has to be cut, although you should cut your valve cover on the side to aid in tuning (adjusting the gears)
