Coolant Lines reroute TB
Old Oct 13, 2006 | 01:45 PM
lude98SH's Avatar
Default Coolant Lines reroute TB
After the lines have been reroute away from the TB. What do you do with the end connections on the FITV ?
Old Oct 15, 2006 | 12:54 PM
lude98SH's Avatar
Default Re: Coolant Lines reroute TB (lude98SH)
bump
Old Oct 15, 2006 | 01:21 PM
cgo_62's Avatar
when i did my coolant bypass mod, i went here http://www.92lude.com/coolant_bypass.htm
in stock form: block (out) --> TB (in) --> IM (out) --> block (thermo housing - in)
note that the coolant circulates from the block to the TB, thru the valve of the intake mani and back to the thermostat housing which is the block again.
in mod form : block (out) --> block (thermo housing - in)
IM(out) --> TB (in)
note the coolant from the block (out) goes directly back into the thermostat housing, which essentially is the block (in)
and the line from the IM (out) goes to the throttle body without any coolant.
Old Oct 15, 2006 | 06:11 PM
lude98SH's Avatar
Default Re: Coolant Lines reroute TB (cgo_62)
Has anyone ever used a plate with a rubber gasket on it and blocked off the TB where the FITV used to be and completely removed it ? Or is that not possible because u still have the open connection on the TB ?
Old Oct 15, 2006 | 07:27 PM
BlUAc's Avatar
ya thats what I did I used an aluminum plate with the seals on the fiv and sealed it with some silicone
Old Oct 16, 2006 | 06:28 AM
lude98SH's Avatar
Default Re: Coolant Lines reroute TB (BlUAc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlUAc &raquo;</TD></TR><TR><TD CLASS="quote">ya thats what I did I used an aluminum plate with the seals on the fiv and sealed it with some silicone</TD></TR></TABLE>
What did u do with the coolant intake on the TB itself, just cap it ?
forbiddenera
Jan 6, 2017 04:32 AM
joel n
May 5, 2013 05:39 PM
ArchAngel Sabastian
Jun 14, 2008 04:10 PM
93(Civic)EG6
Nov 8, 2006 08:48 AM
turbotime
Nov 5, 2005 12:34 AM
