Geniune Fluids only for 96 Honda Accord EX?
Old Oct 13, 2006 | 01:18 PM
hungtat's Avatar
Default Geniune Fluids only for 96 Honda Accord EX?
The manual states that use only geniune Honda power steering fluid or brake fluid when refilling those parts. Is that really necessary or will generic brands out there do just fine?
Old Oct 13, 2006 | 02:45 PM
rollercosta123's Avatar
Default Re: Geniune Fluids only for 96 Honda Accord EX? (hungtat)
i dont know about the break fluid but if you go to a auto parts store they might have power steering fluid for honda. i have seen it. break fluid you should use honda fluid because it dose corrode. you should also by genuine honda 50/50 or prestones dont buy any other ****
Old Oct 13, 2006 | 04:20 PM
pos_cd5's Avatar
any reputable brand that is compatible with your honda is fine.
Old Oct 13, 2006 | 08:05 PM
Default Re: Geniune Fluids only for 96 Honda Accord EX? (pos_cd5)
oem or corroded parts. which do you preffer? oem? corroded
Old Oct 14, 2006 | 08:19 AM
YeuEmMaiMai's Avatar
Would I use anthing other than Honda OEM?
Transmission? : NOT A CHANCE
PS fluid? : NOT A CHANCE
Coolant? : Sure as long as it meets specs
Brake fluid? : Sure as long as it was a quality name brand that meets the specs
Old Oct 14, 2006 | 02:26 PM
ilikehonda's Avatar
Default Re: (YeuEmMaiMai)
for the tranny a good combo is to use honda and gm syncromesh
Old Oct 14, 2006 | 04:19 PM
businessmanph's Avatar
Default Re: (ilikehonda)
for power steering use honda
brake fluid i used prestone just flush it every 3-5 years
Old Oct 14, 2006 | 05:18 PM
importfanatic17's Avatar
Default Re: Geniune Fluids only for 96 Honda Accord EX? (rollercosta123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollercosta123 &raquo;</TD></TR><TR><TD CLASS="quote">oem or corroded parts. which do you preffer? oem? corroded </TD></TR></TABLE>
is corroded a parts manufacturer too? OEM, JDM, CEM...? lol
Old Oct 16, 2006 | 12:26 PM
hungtat's Avatar
Default Re: Geniune Fluids only for 96 Honda Accord EX? (importfanatic17)
My friend warns me not to add the brake fluid to the max if it falls below because even a very tiny piece of dust in there will cause a lot of problem. Do you agree?
I am going to buy geniune fluids from Ebay today.
Old Oct 16, 2006 | 02:01 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hungtat &raquo;</TD></TR><TR><TD CLASS="quote">My friend warns me not to add the brake fluid to the max if it falls below because even a very tiny piece of dust in there will cause a lot of problem. Do you agree?
I am going to buy geniune fluids from Ebay today. </TD></TR></TABLE>
you friend is a tool
and what he/you said makes no sense.
Old Oct 16, 2006 | 05:18 PM
pos_cd5's Avatar
Default Re: Geniune Fluids only for 96 Honda Accord EX? (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
i think he was kidding. because everyone should know that nothing on ebay is genuine
Old Oct 16, 2006 | 11:05 PM
lxaccord51oxl's Avatar
to add. when you refill your brake or power steering, do you have to flush it or just pore it in. I jus pore it in, just wana know if i did it right. I always used honda powersteering and honda brake fluid because it says it on the cap to use only honda genuine fluids.
Old Oct 17, 2006 | 02:45 AM
The_Todd's Avatar
Farts in the shower
Default Re: Geniune Fluids only for 96 Honda Accord EX? (lxaccord51oxl)
I always use honda tranny fluid, brake fluid and p/s fluid...just better to be safe than sorry.
Old Oct 17, 2006 | 06:16 AM
hungtat's Avatar
Default Re: Geniune Fluids only for 96 Honda Accord EX? (.ken)
Good question. So do you just pore the fluid in to fill it back to the max level? Or should flush it first before poring anything in?
Where can I find geniune honda fluids if not on Ebay?
Old Oct 17, 2006 | 08:53 AM
specbb6's Avatar
All the fluids I use on my car are Honda fluids. Why, because they're good products. In the past Ive tried several other brands on almost every area and Honda seems to have the same or better quality than those aftermarket ones.
Plus, you dont want to take the chances of messing w/ your tranny for using synchromesh (sp?) or Royal Purple, products that ppl think are reall good stuff but are not designed specially for honda's.
I use Honda products on all the following: P/S fluid, Brake fluid, and Tranny fluid, Coolant. For motor oil I use Mobil 1.
Old Oct 17, 2006 | 07:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hungtat &raquo;</TD></TR><TR><TD CLASS="quote">Good question. So do you just pore the fluid in to fill it back to the max level? Or should flush it first before poring anything in?
Where can I find geniune honda fluids if not on Ebay?</TD></TR></TABLE>
you can find genuine honda fluids at your local auto shop. autozone, pepboys, anywhere where basically.
i use castrol gtx high mileage for my oil change. its 140k
Old Oct 17, 2006 | 08:04 PM
specbb6's Avatar
your local Honda stealership should have plenty of them. dont trust ebay, ebay is gay.
Old Oct 19, 2006 | 01:23 PM
Default Re: Geniune Fluids only for 96 Honda Accord EX? (specbb6)
Make sure to refill your blinker fluid when you are changing your other fluids. I think Honda makes a fluid for those too.
Old Oct 19, 2006 | 02:47 PM
pos_cd5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importfanatic17 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure to refill your blinker fluid when you are changing your other fluids. I think Honda makes a fluid for those too. </TD></TR></TABLE>
while you do that, since your already down there make sure to check your clutch belt too.
W95civicEXcoupe
17
Apr 14, 2015 06:11 AM
jmk64
May 11, 2006 10:05 AM
jdmludeaz
Apr 11, 2006 05:05 AM
UncleRay
Feb 5, 2003 07:11 AM
jetli
Oct 31, 2001 12:11 PM
