cel on/off on its own...
Old Oct 13, 2006 | 11:39 AM
aych2h's Avatar
Default cel on/off on its own...
i have a 99ls..engine bone stock..and my CEL came on the other day...wasnt driving it hard or anything..totally random..i turned it off then back on..still there..and the next morning as i was driving it, the light went off by itself and hasnt come back for a couple days now..this is the second time this has happened to me...can anyone give me an explanation?? car seems to run just fine.... thanks in advance...
Old Oct 13, 2006 | 01:57 PM
Deluzional's Avatar
Default Re: cel on/off on its own... (aych2h)
pull the code and figure out whats wrong..we cant help you out much until you figure out what code your car is throwing
Old Oct 13, 2006 | 02:03 PM
Dogginator's Avatar
Daisy... Daisy...
There is a thread in the Integra FAQ thread explaning how to pull the CEL codes.
https://honda-tech.com/zerothread/1230496
Old Oct 14, 2006 | 07:08 AM
aych2h's Avatar
Default Re: cel on/off on its own... (Dogginator)
cool..ill do that today and get back to you guys...thanks..
Old Oct 14, 2006 | 11:20 AM
aych2h's Avatar
73 random misfire cylinder 3
91 Evaporative Emission Control System insufficient purge flow
these are the codes i pulled....the 73 i have no idea bout, random misfire? is this something serious that i need to look into?...but the 91...could that be like my gas cap not being on tight enough??caus i remember i didnt have a gas cap for a little bit and that made my light come on a while back.. i dont have my CEL on right now...any help is appreciated
Old Oct 14, 2006 | 11:29 AM
Dogginator's Avatar
Daisy... Daisy...
The random misfire could be a bad spark plug, poorly adjusted valves, bad plug wire, etc. Does the CEL illuminate at low or high RPM?
Old Oct 14, 2006 | 11:34 AM
aych2h's Avatar
well it came on when i was at round 3-3.5k rpm in 5th...jus normal highway driving...and went off a couple days later..this morning i pushed the car a tad bit..and seemed to run fine...
Old Oct 14, 2006 | 03:23 PM
aych2h's Avatar
info anyone?
Old Oct 17, 2006 | 06:09 AM
aych2h's Avatar
anyone????
Old Oct 17, 2006 | 06:43 AM
Dogginator's Avatar
Daisy... Daisy...
Check that your plug wires are tight. You can also check the spark plugs, wires, and distributor cap and rotor.
Old Oct 17, 2006 | 07:03 AM
aych2h's Avatar
thanks..will check
Old Oct 19, 2006 | 07:32 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
any update?
Old Oct 19, 2006 | 09:01 AM
aych2h's Avatar
Default Re: cel on/off on its own... (SupersonicBlueGSR)
naw..havent been able to make it to the shop to work on it....this weekend imma check those things though..
slowesteg
May 11, 2012 11:07 PM
crxowner
Oct 12, 2011 02:54 PM
h22bb1
May 22, 2008 09:25 PM
98CivHx
Sep 11, 2006 11:31 AM
JoshuaVTEC
Feb 27, 2005 03:02 AM
