Honda S2000 Honda S2000
Hood Dampners and CB Hoods
Old Oct 13, 2006 | 11:37 AM
mytoesarecrazy's Avatar
Default Hood Dampners and CB Hoods
Whats up everyone..does anyone know if the hood dampners will work ok with a carbon fiber hood? I'm pretty sure it will fit and all but, will the dampners put too much stress on the CB hood that it will strip the hole?
http://www.tein.com/hooddamp.html
Old Oct 13, 2006 | 11:51 AM
immortal's Avatar
Banned
Default Re: Hood Dampners and CB Hoods (mytoesarecrazy)
NRG just released some updated "half pressure" hood dampers that were designed for FRP & carbon fiber hoods - they also still work well with OEM hoods.
i'm pretty sure the other hood dampers will work fine on CF/FRP as well.. just pay attention when you are opening/closing the hood.
Old Oct 13, 2006 | 12:49 PM
Shadow_S2K's Avatar
Default Re: Hood Dampners and CB Hoods (immortal)
Will work fine. I have Teins on my c/f hood. Onlt the first inital compression of the dampners is very hard, as they are very stiff. Some people have managed to compress it on the ground first before installing...but other than that it will work fine.
Old Oct 13, 2006 | 12:59 PM
Thanks for all the info.
Old Oct 13, 2006 | 01:23 PM
sixsixsix's Avatar
OneWayHighway
ya NRG released those new half pressure ones. My buddy has those in stock only in CF finish.
I have the Top Secret Hood Dampers and those are also made for CF or FRP hoods.
Old Oct 13, 2006 | 01:26 PM
itr-j's Avatar
Default Re: Hood Dampners and CB Hoods (sixsixsix)
Top secret and Vision make hood dampers too. I'm using the Vision technica ones. Identical to the Tein ones but aren't green.
Old Oct 16, 2006 | 06:06 PM
Kingsta18's Avatar
Default Re: Hood Dampners and CB Hoods (itr-j)
Do the damper's raise the hood higher than the OEM holder? It just isn't high enough?
Old Oct 16, 2006 | 06:36 PM
Jet.'s Avatar
I have NRG hood dampers and they work fine. Like some people did, you may have to compress them on the ground or some other way so you can "break them in."
Shaynepolevault
Sep 2, 2008 08:20 PM
lblingldawg
10
Apr 21, 2006 07:27 AM
Feuerraeder
Nov 25, 2003 03:45 PM
Dr Pooface
Sep 27, 2002 07:06 PM
