How do i rotate to TDC with camshafts off
Old Oct 13, 2006 | 11:10 AM
drumminforev's Avatar
Default How do i rotate to TDC with camshafts off
Im doing valve seals, and cams have to be out for that. so now im ready to move on to the next cylinder,
how do i rotate to tdc so the valves are closed for the next cylinder without reinstalling the entire cam assembly
Old Oct 13, 2006 | 11:14 AM
Default Re: How do i rotate to TDC with camshafts off (drumminforev)
nevermind brain fart. valves will all be closed wit no cams installed
Old Oct 13, 2006 | 11:35 AM
drtyhatch's Avatar
LOL...
I get those farts sometimes too.
Old Oct 13, 2006 | 11:36 AM
Dartanian's Avatar
You still want to have the piston at TDC for that cylinder so that in case the valve gets dropped, you won't have to pull the head off. Rotate the crank and determine TDC with a flashlight in the spark plug hole or a long screwdriver in the spark plug hole.
SingleCamin
20
Aug 3, 2011 11:42 AM
89civichb
Mar 7, 2009 07:45 PM
drumminforev
Oct 13, 2006 08:52 PM
wildoutwhitegsr
Jan 27, 2006 08:42 PM
Layziebtnh055
May 7, 2004 07:29 AM
