compression test results
Old Oct 13, 2006 | 10:09 AM
Fat Chick Magnet's Avatar
Default compression test results
2000 em1 Si
cyl 1= 170 cyl 2= 170 cyl 3=170 cyl 4= 170
the mechanic did it twice and the same numbers came out. does that mean my car is burning oil now?
Old Oct 13, 2006 | 12:36 PM
Lu DC2's Avatar
Default Re: compression test results (dc2rtek)
sounds good. we compression tested my brother's second gen JDM B16 and the numbers came out 180-185 all the way across. don't worry, it's fine. As long as there isn't a difference of more than 40% between cylinders, you're fine.
Old Oct 13, 2006 | 01:20 PM
kodarren's Avatar
i have a 98 gsr engine on my civic
i got 200 210 210 200
Old Oct 13, 2006 | 08:15 PM
egsir2's Avatar
Default Re: compression test results (kodarren)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kodarren &raquo;</TD></TR><TR><TD CLASS="quote">i have a 98 gsr engine on my civic
i got 200 210 210 200 </TD></TR></TABLE>
nice.
Old Oct 13, 2006 | 09:30 PM
H9Omega's Avatar
on my b16a2 i got 230 all across the board
Old Oct 13, 2006 | 09:45 PM
Si_chRis's Avatar
Default Re: (H9Omega)
kinda low, did the mechanic pull ur injector plugs and hold it a wide open throttle? On a b16a2, it should be around the 200 psi range
Old Oct 13, 2006 | 09:47 PM
cambopheonix56's Avatar
Default Re: (EM1_ChRiS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_ChRiS &raquo;</TD></TR><TR><TD CLASS="quote">kinda low, did the mechanic pull ur injector plugs and hold it a wide open throttle? On a b16a2, it should be around the 200 psi range</TD></TR></TABLE>
Yea, that is a little low. Did you do it at operating temp?
Old Oct 13, 2006 | 09:48 PM
Default Re: (cambopheonix56)
Must have been an error, since they are all consistant.
Old Oct 15, 2006 | 01:23 PM
godunovs's Avatar
I have a 2000 GSR. Tested the compression today. 215 across all four. The nominal pressure is 213, mimimum is 135. Variation between cylinders is 28. Your numbers look fine.
Old Oct 15, 2006 | 01:51 PM
bluevic99's Avatar
Default Re: compression test results (godunovs)
I always get 210 or 215 on all cylinders in my b16a2
Old Oct 19, 2006 | 07:32 PM
del_slow420's Avatar
Default Re: compression test results (bluevic99)
i got 270 all the way accross on my b20vtec with 12.5:1 compression think thats any good?
Old Oct 19, 2006 | 08:20 PM
Default Re: compression test results (del_slow420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_slow420 &raquo;</TD></TR><TR><TD CLASS="quote">i got 270 all the way accross on my b20vtec with 12.5:1 compression think thats any good?</TD></TR></TABLE>
Yes.
Old Oct 19, 2006 | 08:34 PM
t0p_sh0tta's Avatar
Default Re: compression test results (cambopheonix56)
lol... I tested my D15B8 the other day.
180 - ~10 - 200 - ~10
Carbon build up FTW. I'll be swapping it out tomorrow (weather permitting).
lee0149
Feb 6, 2009 10:33 AM
Honda_Cribb_GS-R
25
Sep 10, 2008 04:05 PM
MadCityLude
Feb 20, 2007 11:17 AM
snowblind7x
Apr 13, 2005 08:12 PM
RCautoworks
Aug 23, 2003 05:27 PM
