will it rub the inside fender? and will the wheel stick out of the fender?
Old Oct 12, 2006 | 10:53 PM
ek9child's Avatar
Default will it rub the inside fender? and will the wheel stick out of the fender?
another question i had was if i would be able to fit 205/50R15 tires on my 95 civic coupe without rubbing or turning issues? the car is droped 1.5inches and i have 195/50R15 tires on right now with no rubbing issues what so ever. just wondering if i could fit wider tires on there..
Since we're talking street tires for daily driving, stick with 195/50-15. I'm not sure about rubbing - it's very possible, especially on a lowered car. In addition, the 205/50-15 will make your car accelerate slower (like getting taller gears) and will make your speedometer and odometer inaccurate. The 195/50-15 tires are cheaper, too...
Old Oct 12, 2006 | 11:02 PM
r.wright's Avatar
Default Re: will it rub the inside fender? and will the wheel stick out of the fender? (ek9child)
i think u just answered yer own question...205 may be wider but wont do anything to benifit yer car except for having a wider tire.....
Old Oct 12, 2006 | 11:16 PM
ek9child's Avatar
Default Re: will it rub the inside fender? and will the wheel stick out of the fender? (mrrlx)
how come lambo have wider tire? and y does slick tire are so wide? if it dont have any benefit..
Old Oct 12, 2006 | 11:27 PM
r.wright's Avatar
some cars need wider tires to match their powertrain.
Old Oct 15, 2006 | 04:21 PM
blub18's Avatar
wider tire do help it's a "bigger foot print" lot more grip. try putting a civic si rim and tire on a cobra your gonna spin your *** off.
Old Oct 17, 2006 | 03:01 PM
FalkenSiR's Avatar
Default Re: will it rub the inside fender? and will the wheel stick out of the fender? (blub18)
It won't rub. Just make sure the wheel has at least a 38-40mm offset
Old Oct 17, 2006 | 04:10 PM
Leo C's Avatar
Night Owl
Having a wider tire is not the best idea for a daily driven car. Instead of buying a wider tire, spend that $ on a stickier tire in 195/50/15. Which is the proper size for your car.
Old Oct 17, 2006 | 10:17 PM
vtecsi00's Avatar
Default Re: will it rub the inside fender? and will the wheel stick out of the fender? (Leofski)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leofski &raquo;</TD></TR><TR><TD CLASS="quote">Having a wider tire is not the best idea for a daily driven car. Instead of buying a wider tire, spend that $ on a stickier tire in 195/50/15. Which is the proper size for your car. </TD></TR></TABLE>
would have to agree goodyear makes the F-1 in your size that would do the trick
Old Oct 17, 2006 | 10:24 PM
Leo C's Avatar
Night Owl
Default Re: will it rub the inside fender? and will the wheel stick out of the fender? (vtecsi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">
would have to agree goodyear makes the F-1 in your size that would do the trick</TD></TR></TABLE>
Good call.
Also consider the Kumho Ecsta SPT if you want to spend about half as much as the F1. Both are very good tires.
Guitargeak99
Honda Civic (2001 - 2005)
Apr 1, 2019 03:11 AM
Loumarino800
Honda Insight & CR-Z Hybrid
Oct 7, 2018 05:33 AM
crvb20z
Dec 31, 2009 05:47 PM
TylerLorenz
Oct 6, 2009 04:17 PM
doggworld1233
42
Mar 29, 2006 01:53 PM
