cade 9 need help cant seem to fix it.
Old Oct 12, 2006 | 09:57 PM
2poor2tune's Avatar
Default cade 9 need help cant seem to fix it.
ok good old code 9 ive seen it on every one of my swaps. now i have wired it correctly i know this but if you want to put check again you can i will probly do it many times unless there is another solution to this. i so code 9 is cylider no. 1 position sensor. located in the dizzy correct? and it is the 2 wires comming from the dizzy plug. blue/green and blue/yellow. now i understand that these need to be wired to c1 and c2 on plug c of coarse and cannot figure out why the code wont go away. i have reset the ecu also. and still it did not help. any suggestions for me.
Old Oct 12, 2006 | 10:01 PM
projsectEF's Avatar
Default Re: cade 9 need help cant seem to fix it. (2poor2tune)
what motor do you have? Ecu? and dizzy? and it starts up right?
Old Oct 12, 2006 | 10:05 PM
2poor2tune's Avatar
no not really i have my own ignition switch cuz the stock wouldent work and because of theft reasons. and its a b16 with a pr3 and runs fine when its started and my switch seems to start it up very good. like stock. idles high tho. i just want my codes gone for turbo time baby. yea oh and i guess just the stock dizzy. but i could check real quik for you. ill be back.
Old Oct 12, 2006 | 10:06 PM
xx89civicracer89xx's Avatar
Default Re: cade 9 need help cant seem to fix it. (projsectEF)
ya wat motor u got? cuz i know with my dohc zc i had to wire it to my ecu...
Old Oct 12, 2006 | 10:22 PM
2poor2tune's Avatar
ok its a b16a dizzy is what i was told from the guy off ebay. and the tag is ripped off of it so i cant tell what kind of dizzy it is. help me real quik please.
Old Oct 12, 2006 | 10:29 PM
Default Re: (2poor2tune)
got any pics of ur engine bay? are u runnin obd 0 still ?
Old Oct 14, 2006 | 01:19 AM
2poor2tune's Avatar
Default Re: (xx89civicracer89xx)
yes i am. and i still havent got rid of this damn code yet. might be the dizzy. i will see if i can swap out one of my frinds and see if it goes away.
stumy10
Jan 13, 2015 02:19 PM
crxpwr1
18
Apr 3, 2007 11:21 AM
G2Crash
Jan 13, 2005 01:33 AM
Blaze45
Jul 2, 2003 07:58 PM
fast-rex
Jan 28, 2003 01:35 PM
