CEL, when @ 5200-5600 RPMS
Old Oct 12, 2006 | 08:58 PM
Metal Head's Avatar
Default CEL, when @ 5200-5600 RPMS
<U> My car 1995 Civic EX coupe w/ D15B vtec swapped, stock virgin P28</U>
So I am in 5th gear on the highway, I drop it to 4rth gear WOT it and about 5200-5600 ( I don't remember, but it was around 5K, pretty high) and CEL comes on. So I quickly turn car off then on (while still driving) codes goes away. Do the same exact thing and CEL comes on again!
So at high RPMS CEL comes on.
The code is #22 Two long 2 short blinks
<U>I have done the following since the code:</U>
Swapped out the WHOLE vtec sensors with a new one,
Wired VTEC Directly to my ECU with my own wires to A4 and D6 on the ECU
I have ALOT of black SOOT ALL over the rear bumper, I always have alot of black soot, I can litterally write words with my fingers in the black soot on my rear bumper
HHHHHHEEEEELLLLPPPPPP<U></U>
Old Oct 13, 2006 | 08:19 AM
Metal Head's Avatar
Default Re: CEL, when @ 5200-5600 RPMS (IloveYOURmom)
TOP Is VTEC working??
Old Oct 13, 2006 | 10:15 AM
The_Head's Avatar
knock sensor maybe?
Old Oct 13, 2006 | 11:31 AM
Metal Head's Avatar
Default Re: CEL, when @ 5200-5600 RPMS (The_Head)
OBD1 sorry
Old Oct 13, 2006 | 11:43 AM
Sloshy's Avatar
maybe you should see what the cel is and that will tell you where to start..
Old Oct 13, 2006 | 11:54 AM
grayegcivic's Avatar
Same exact thing on my 92 si..hit that 5000 rpm range..cel is on....loose knock sensor.
Old Oct 14, 2006 | 06:21 PM
Metal Head's Avatar
Default Re: CEL, when @ 5200-5600 RPMS (grayegcivic)
OBD1 no knock sensor!!!!!!!!!!!!!! D15B VTEC OBD1
ok, so I noticed, if I were to get on it in first gear or even downshift into second and rap the rpms all the way to 7K the CEL doesnt come on, the cel only came on when I was on the highway traveling at a constant speed and only did it when I downshifted from 5th into 4rth and mashed on the gas and took it to 5K+
The code is for #22 Vtec pressure solenoid.
I put a brand new solenoid in!
Old Oct 14, 2006 | 06:46 PM
The_Head's Avatar
Whoa, calm down there. OBD1 B16A's have a knock sensor, that's what made me guess that. It was just a guess.
Old Oct 14, 2006 | 07:26 PM
Metal Head's Avatar
tru tru, is all good,
Michael Ancira
Jan 15, 2017 04:49 PM
Metal Head
26
Jan 6, 2007 06:34 PM
SearchBeforeUPost!
Mar 31, 2004 05:39 PM
-Whitey-
Feb 3, 2003 02:39 PM
