What distributor for my OBD2B B16A2?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SyDuck »</TD></TR><TR><TD CLASS="quote">What distributor will work and fit the bolt pattern for my OBD2B B16A2?
thanks!</TD></TR></TABLE>
An OBD-2 B-series VTEC distributor . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
An OBD-2 B-series VTEC distributor . . .</TD></TR></TABLE>
that is true, very true.
An OBD-2B B-series VTEC distributor . . .</TD></TR></TABLE>
Apparently, all the B-series OBD-2 distributor plugs are the same, regardless of "A" or "B," because the Honda parts catalog is showing the exact same distributor for '96-97 del Sol VTEC and '99-00 Civic Si . . .
The Acura catalog is also showing the same numbers for '98 and '99 Integra VTEC distributors.
Edit: This apparently only applies to B-series, because it was brought to my attention (and I confirmed via both the Honda parts catalog and Distributor King's catalog) that the D-series distributors are indeed different for the "A" and "B" variations of the OBD-2 system.
Modified by Targa250R at 8:18 PM 10/16/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Apparently, all the B-series OBD-2 distributor plugs are the same, regardless of "A" or "B," because the Honda parts catalog is showing the exact same distributor for '96-97 del Sol VTEC and '99-00 Civic Si . . .
Modified by Targa250R at 8:18 PM 10/16/2006</TD></TR></TABLE>
NICE!
OBD2B for integra is 00-01
NICE!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">NICE!
Acura parts catalog shows the same distributor for '98, '99, '00, and '01.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SyDuck »</TD></TR><TR><TD CLASS="quote">I am using a obd2b GSR dizzy, and the bolt pattern does not match mine.</TD></TR></TABLE>
What is the number on the distributor housing (TD-xxU)? What is different about the bolt pattern? Are you sure you didn't get the wrong distributor?
</TD></TR></TABLE>Acura parts catalog shows the same distributor for '98, '99, '00, and '01.
What is the number on the distributor housing (TD-xxU)? What is different about the bolt pattern? Are you sure you didn't get the wrong distributor?</TD></TR></TABLE>
i dont know, i have the right distributor because it plugs up and works for now... until i can find a replacment that will bolt up perfectly. currently and temporarily, my distributor is being held on by only 1 bolt on the top. the rest do not line up.
my friend loaned it to me and said it was from a GSR. my stock one was stolen.
my motor is a 99-00 B16A2
Integra 94-97 were OBD2A, 98-01 were OBD2B.
cleanej2
Aug 9, 2007 04:01 AM
vxnine
Jul 25, 2005 03:20 PM
98 itr
