Looking into making C-pillar and REar strut bars. Help?
I am looking at making a rear C-pillar bar and a Rear strut tower bar.
The C-pillar bar will bolt up to the stock rear seatbelt locations.
The strut bar will bolt up to the two mount locations on the shock tower.
I will use a nice stiff peice of square 1" steel tubing for the actual bars. I also have access to a welder, so that is not a problem.
The only problem I am having is the mounting locations. How can I make a plate or somthing to slide over the shock bolts?
How can I make a bracket to bolt onto the seatbelt location? Anyone got pix?
Aight, I was thinkng about this. instead of making one strut bar and a horse-shoe shaped peice that went to both bolts on the tower, I would do two bars, one for each mounting bolt. Like this pic: (the bar is standard square tubing.)
agreed.. if you braced them together on each end, you would take out the twist/flex factor!
Also, you might want to look into it but it might benifit you to jack the car up at a center point b4 taking measurments.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">So make like an:
---|-----|---</TD></TR></TABLE>
yes, that would eliminate the flex & increase stability. I would personally put the 2 connecting bars twords the ends.
That would definatly be more flex resistant than a single bar.
I did exactly what you guys are talking about. Worked great. After a couple years, I took that out, redid it with round tubing and made a bar that is like the passwordjdm bars that rear down to the trunk floor as well. I did mine about 6 months before their's hit the market and sold a few. Everyone loves them.
So, friggen do it! You will love it. It ties the back end together much better than any aftermarket bar I had in the past.
You are taking all the strength out of that tube by cutting the end like that.
It will bend very easily.
If you want to do it like that at least take a piece of flat bar and bend it and weld it in the end there.
bolting a bar down to help handling is not always a good idea. the movement you have in the mounting location will be the same when the chassis is actually moving. you would need to weld the bars directly to the chassis for it to be useful. not trying to down the project or anything. just the way it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman »</TD></TR><TR><TD CLASS="quote">bolting a bar down to help handling is not always a good idea. the movement you have in the mounting location will be the same when the chassis is actually moving. you would need to weld the bars directly to the chassis for it to be useful. not trying to down the project or anything. just the way it is.</TD></TR></TABLE>
Strut bars are a very common thing. I don't see the problem. And I also have a new idea thanx to my boys in the EF Forum.
Timmay made a set for his 4dr EG (the silver one for those of you that know him) about 4 or 5 years ago now. i dunno if he reads this forum but i bet he has pics, it looked pretty good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">Nice, bt again, I don't have the facilities to cut metal to make those mounting brackets.</TD></TR></TABLE>
I made it in my garage, made it with an angle grinder, drill, and a welder.
you get the idea from the shitty pic I hope??? I already have mounting brackets on the shocktowers from my current rear strut bar, so I was just gonna use a piece of 1.5" tubing thats laying around the shop, flatten the ends a little in a vise and put that in there with some bolts. As for the seatbelt locations I was gonna make brackets out of 7/16 or 1/2" steel, whatever is laying around, and bolt them up then fit 2 more pieces of steel tubing in there at angles like shown and weld it all up. Easy hour job to do at school, with free materials I might add. haha
What the hell if I dont like it Ill sell it on ebay right
does anybody know if home depot would have the materials for this and what is a good type of pipe/tube to use for this i want it stif and strong but not ridiculously heavy and i just have a mig im gonna have to get in on this project too will this be as stiff as a say 6 point cage if i also tie in to the b pillars since it mounts to the body and it is a unibody chasis
