HOW MUCH BOOST?
Old Oct 12, 2006 | 05:25 PM
Stealth Teg's Avatar
Default HOW MUCH BOOST?
WHAT THE LIMIT OF PSI I CAN HANDLE ON A STOCK B16A? AND WHA WOULD I NEED TO DO TO BE ABLE TO PUSH IT UP TO 10 10PSI? I DROPPPINF A PEAK BOOST TURBO KITS UP IN MY 90 TEGGIE! PLEASE HELP! DON'T JUST READ IT AND FLOP OUT...
Old Oct 12, 2006 | 05:39 PM
str8JDMteggy's Avatar
10 psi on a stock b16 = NO PROBLEM.
Old Oct 12, 2006 | 08:18 PM
AznPrideYo's Avatar
Default Re: (str8JDMteggy)
10 psi on a peak boost kit will need a killer tune. you will be well into the 300-350 whp range
Old Oct 12, 2006 | 09:57 PM
ImportMotorSpec's Avatar
Default Re: (AznPrideYo)
All you need is a good tuner and you will be fine with 10 psi
Old Oct 12, 2006 | 10:04 PM
LordAphotic's Avatar
PSI DOESNT MEAN **** GOD DAMN IT!!!!!
different turbos will give different volumes of air at the same PSI....
lets say you have a tiny as volvo turbo with A/R .42 on the cold side and a big *** turbo with A/R .90 on the cold side. and they are both running 10psi..... guess which one is gona blow your engine to another dimension?
Old Oct 12, 2006 | 10:05 PM
SeArCh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! expletive man.
Old Oct 13, 2006 | 12:41 AM
teknoracing's Avatar
Default Re: (LordAphotic)
thank you!!!!!!!!!
I hate this question as well. Research your stuff man and come back with a more specific question
Old Oct 13, 2006 | 06:29 AM
Default Re: (teknoracing)
I JUST WANNA GET SUM ANSWER FROM YOU GUYS ABT 10 PSI ON A STOCK B16A BOTTOM, BUT THE HEAD WOULD BE BUILD. I DID SOME RESEARCH ON IT, BUT IT SEEM NOT ENOUGH. I DON'T HAVE RESPOND WHEN I WANT QUESTION ABT IT. SO A GOOD KILLER TUNE, CAN IT BE HONDA DATA? I JUST KNOW I WILL BE AROUND THE 320- 345 HP RANGE. SO HELP ME WHA I SHOULD DO. YES- I DOING RESEARCH ALSO. THERE ARE ALWAY BETTA ANSWER WHEN U ASK AROUND....
Old Oct 13, 2006 | 08:43 AM
Hawkze_2.3's Avatar
Default Re: (Stealth Teg)
YOU GOT YOUR ANSWER TO DO SOME RESEARCH SO GO DO IT!!! THEN TURN OFF THE CAPS LOCK AND ASK MORE SPECIFIC QUESTIONS!!111
Old Oct 13, 2006 | 08:51 AM
Jake1220's Avatar
50PSI with a FMU
Old Oct 13, 2006 | 09:00 AM
Rikter's Avatar
If you run one FMU you're good to 10psi but to be on teh safe side you should run two FMU's and you can boost up to 15-18psi on a stock bottom end no problem. Wait.. you've got head work? K up that to 20psi but use the honda data tune like you plan and you should be fun. Just make sure that you run 10w30 oil though as you want to make sure it's going to coat your cylinder walls really well. What type of wastegate will you be running? Put in a 30psi spring just in case you decide to build the bottom end later. You should be fine for hte occasional boost spikes so don't worry about that.
If you can run one stage cooler sparkplugs too.
Show us your dynograph when you're done
-Rik
Old Oct 13, 2006 | 09:41 AM
Default Re: (Rikter)
Rikter? You explain it all. You got the answer I looking for. Now I knw what I gotta do. Thank...
Old Oct 13, 2006 | 09:47 AM
95dc2teg's Avatar
lol....wow
Old Oct 13, 2006 | 10:01 AM
HoUTX98GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter &raquo;</TD></TR><TR><TD CLASS="quote">If you run one FMU you're good to 10psi but to be on teh safe side you should run two FMU's and you can boost up to 15-18psi on a stock bottom end no problem. Wait.. you've got head work? K up that to 20psi but use the honda data tune like you plan and you should be fun. Just make sure that you run 10w30 oil though as you want to make sure it's going to coat your cylinder walls really well. What type of wastegate will you be running? Put in a 30psi spring just in case you decide to build the bottom end later. You should be fine for hte occasional boost spikes so don't worry about that.
-Rik</TD></TR></TABLE>
Yeah...what he said.
*snicker* *cough*
Old Oct 13, 2006 | 10:05 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: (HoUTX98GSR)
Old Oct 13, 2006 | 11:34 AM
sahtt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LordAphotic &raquo;</TD></TR><TR><TD CLASS="quote">PSI DOESNT MEAN **** GOD DAMN IT!!!!!
lets say you have a tiny as volvo turbo with A/R .42 on the cold side and a big *** turbo with A/R .90 on the cold side. and they are both running 10psi..... guess which one is gona blow your engine to another dimension?</TD></TR></TABLE>
THANK YOU. After correcting 7 billion people, I realized anyone who is serious enough about boost to actually do it is going to figure that out along the way.
It's amusing how many people with XXXX posts talk about boost and don't know the BARE BASICS.
---Use WHP NOT psi---
Old Oct 13, 2006 | 12:54 PM
Default Re: (sahtt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sahtt &raquo;</TD></TR><TR><TD CLASS="quote">
---Use WHP NOT psi---</TD></TR></TABLE>
Well uhhhh :thumbup, u gotta crawl before u walk....
Old Oct 13, 2006 | 01:08 PM
RexShop's Avatar
New sig...
Old Oct 13, 2006 | 02:47 PM
Jake1220's Avatar
******* Awsome
93daboy
Aug 24, 2009 03:59 AM
j87w
Feb 14, 2006 09:07 PM
prabtej_si
Jan 25, 2005 09:02 PM
DXRacer
Feb 21, 2003 07:04 AM
