95 Si 2.3 Engine Swap
Well the most common and most popular is a JDM H22. You can get it at Hmotorsonline.com. As far as whats needed, there is TONS of info in the faqs and you can also use the search function to find all the info you need.
Rule of thumb is search first then post for what ever info you could not find.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi-Ra »</TD></TR><TR><TD CLASS="quote">Well the most common and most popular is a JDM H22. You can get it at Hmotorsonline.com. As far as whats needed, there is TONS of info in the faqs and you can also use the search function to find all the info you need.
Rule of thumb is search first then post for what ever info you could not find.</TD></TR></TABLE>
amen to that...there are tons of info in the FAQ> if you read it, you will not go wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 »</TD></TR><TR><TD CLASS="quote">amen to that...there are tons of info in the FAQ> if you read it, you will not go wrong</TD></TR></TABLE>
x123541461463
x123541461463
vango
Apr 10, 2004 06:03 PM
