Best Rear Lower Tie Bar?
Old May 3, 2002 | 12:32 PM
ARACER25's Avatar
Default Best Rear Lower Tie Bar?
What do you all think is the best rear lower tie bar. I am getting the ITR sway bar in a few days and I am looking for information on for a tie bar to go with it.
Old May 3, 2002 | 12:38 PM
ARACER25's Avatar
Default Re: Best Rear Lower Tie Bar? (ARACER25)
And yes I did a search.
Old May 3, 2002 | 12:49 PM
2000GSR's Avatar
get the skunk 2!! its a solid piece! dc sports looks the best but has too much flex.
Old May 3, 2002 | 01:08 PM
comptechgsr's Avatar
Default Re: Best Rear Lower Tie Bar? (2000GSR)
benen
Old May 3, 2002 | 01:16 PM
96GSR's Avatar
New User
Default Re: Best Rear Lower Tie Bar? (comptechgsr)
I too hear that Benen is a good one.
Old May 3, 2002 | 01:20 PM
JCushing's Avatar
my neuspeed rules. its 1 solid peice and is very sturdy. and i found it new for like 70-80 bux
Old May 3, 2002 | 01:33 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Best Rear Lower Tie Bar? (JCushing)
you better get that sway bar mounted directly on your frame instead of on those brackets, otherwise it will probably tear away from the subframe.
Old May 3, 2002 | 01:34 PM
betsuni's Avatar
skunk2 is good!
Old May 3, 2002 | 01:37 PM
VTEConly's Avatar
Neuspeed! All solid, not hollow. Comes with longer bolts and big washers. I felt the difference especially when auto-xing (I have a sway bar too). The rear got tighter and it helps maintain your alignment settings.
I bought the black one (above) for $69.95 + ship. from shox.com. Total price was about $80. I heard DC flexes more than it should.
Old May 3, 2002 | 01:38 PM
reefer_bob's Avatar
Default Re: Best Rear Lower Tie Bar? (VTEConly)
Comptech!!! Super Stiff!
Old May 3, 2002 | 01:53 PM
JCushing's Avatar
Default Re: Best Rear Lower Tie Bar? (PatrickGSR94)
just use the bsq reinforcing kit?
Old May 3, 2002 | 02:16 PM
Community Builder
well that is the skunk2 bar which I believe is made to mount to those brackets instead of to the subframe, like factory, which is probably the cause of reports of subframe tearout w/ the Skunk2 bar. I don't know if you could mount that particular bar to the frame or not, but I would surely try. Those OEM brackets for the GS-R bar really are pretty wimpy.
Old May 3, 2002 | 03:39 PM
Tweakmeister's Avatar
Benen bar is nice, I have it
If I could do it again I'd probably go all comptech...but that's in a perfect world where money grows on trees and there are little chocolate bunnies...err anywho. Neuspeed, Benen, Comptech, they pretty much all do the same thing and in the end the difference is probably not even noticed.
Old May 3, 2002 | 04:08 PM
MikeSarr_GSR's Avatar
Default Re: Best Rear Lower Tie Bar? (Tweakmeister)
I LOVE MY COMPTECH. Bought it second hand, red anodized 22mm set w/swaybar for $250 unused... something about a guy that put it in a shop on consignment which he bought for his chic who blew some other guy... I got lucky in other words.
I painted the thang flat black. No One sees my extra GGGGGs... which is
what I like
Mike In Orlando
Old May 3, 2002 | 04:12 PM
denieone's Avatar
i'll second that
Old May 3, 2002 | 05:44 PM
GSRrR's Avatar
Default Re: Best Rear Lower Tie Bar? (denieone)
I got a generic one for $35.00. Looks exactly like the skunk2 one. Do they really help in handling?
Old May 3, 2002 | 07:02 PM
frogsr's Avatar
actually, the dc sports lower tie bar isn't as bad as their strut braces (which suck *ss). it's pretty solid, but more for those who lookin for little bling bling look. i got rid of mine and got a spoon sports one.
Old May 3, 2002 | 08:32 PM
sa21199's Avatar
Default Re: Best Rear Lower Tie Bar? (frogsr)
my friend has a cusco on his eg
Old May 3, 2002 | 09:03 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Best Rear Lower Tie Bar? (sa21199)
Cusco and Benen are both top notch. I would also say Comptech is up there as well. But... I've found Comptech items to be overpriced copies of other items with there name tag on it. Benen products, if you have ever seen them you know, are TOP QUALITY. Fabulous quality and fair prices for what you get.
DC
Neuspeed
BENEN
Old May 3, 2002 | 09:34 PM
Shingoblade-GSR's Avatar
Default Re: Best Rear Lower Tie Bar? (Pb_Foot)
If there's any comptech part that trounces the competition, its the rear lower tie/sway bar (combo of 2 things) . Their front strut tower bar is also stiffer than anything else out there. Yeah, overpriced, but its the best imo.
Old May 3, 2002 | 10:04 PM
Big Teggie's Avatar
Default Re: Best Rear Lower Tie Bar? (Shingoblade-GSR)
The comptech peice is nice. It mounts almost just like the stock itr one. It is pricey tho compared to the skunk2. The pic really doesnt show how it mounts but gives the idea of the setup.
Old May 3, 2002 | 10:58 PM
PureTeg420's Avatar
Default Re: Best Rear Lower Tie Bar? (Big Teggie)
benen....
Old May 4, 2002 | 06:22 AM
VTEConly's Avatar
Default Re: Best Rear Lower Tie Bar? (GSRrR)
In answer to your question GSRrR, "do they really help in handling", not really that much no. The only time you might notice the car is a little tighter back there is in very hard cornering and when auto-xing I noticed it a bit. Now this had a weird effect on my car. On my first auto-x event after I got the tie bar installed, I noticed the tail was coming around much easier than before and I had not adjusted the Konis since my last auto-x. So after a couple of runs it dawned on me that the only thing different was the addition of the tie bar. I had to dial down the Konis just a little bit in the rear, because if I let off the gas a little in a transition, the car was willing to go sideways a little bit more than before when I had no tie bar.
So I 'd say it's hardly noticeable on the street and slightly noticeable under auto-x racing conditions. That's the best I can describe it..
91 crx savage
Suspension & Brakes
Sep 7, 2010 01:45 PM
^Sammy]!.
Feb 7, 2004 08:15 AM
jDMJeRk
Nov 25, 2003 11:31 PM
Thrillhouse
May 14, 2003 05:50 PM
