Wheel Bearings Maintance
Old Oct 12, 2006 | 03:19 PM
depulse's Avatar
Default Wheel Bearings Maintance
I have 125K on my 94 EX sdn.
I was wondering when some of the high mileager have serviced or changed wheel bearing ( front or rear or both) ?
Old Oct 12, 2006 | 03:27 PM
standbackimapro's Avatar
You dont need to change the wheel bearings unless your having a problem with them
Old Oct 12, 2006 | 03:39 PM
Honda_Accord's Avatar
Default Re: (standbackimapro)
going on 160k on my accord, never once touched the bearings
Old Oct 12, 2006 | 04:09 PM
hondaccord's Avatar
Default Re: (Honda_Accord)
I had 191K on mying and they still ran fine. I did just change them because I did a rotor over hub conversion.
Old Oct 13, 2006 | 08:40 AM
depulse's Avatar
Default Re: (hondaccord)
I was thinking about converting to larger brakes and thought why not change them.
I was also getting noise from the front driver side when I turn and the suspension is compressed. Bearing? or CV joint?
Old Oct 24, 2006 | 03:05 PM
hondaccord's Avatar
Default Re: (depulse)
go with the oem upgrade/swap, there is info up on top. also I have heard of both the c.v., or the wheel bearing giving those noises. just check both next time you get a chance.
twedter02
Jun 14, 2008 06:50 PM
B18c1_turbo
Mar 14, 2008 10:43 AM
spyderazn
Mar 9, 2008 05:28 PM
James
Sep 1, 2004 04:47 PM
Greyout
Dec 3, 2001 07:28 PM
