cars acting weird any ideas
Old Oct 12, 2006 | 03:04 PM
si0385.'s Avatar
Default cars acting weird any ideas
98 hx with z6 head obd2->obd1 conversion harness with a p28 ecu
car ran good since i got it 2 weeks ago
went to start it this morning and it would not start... cranked it a few times and it started but idled extremeley low when i gave it gas it would die if i just tapped the gas and let off really quick it would die than idle really low again... on top of all that it was throwing a ton of codes (5,7,10,1,6,41) eventualy it started and ran fine just throwin code 41 (always has thrown code)
after work i go to start it and same deal but this time the battery dies but it only take 2-3 cranks for the battery to die so i replaced it but it still does the same deal except now i go to start it and when it finaly does run it idles at 2.5 - 3k
any ideas or similar situations?
Old Oct 12, 2006 | 04:08 PM
si0385.'s Avatar
ttt
Old Oct 13, 2006 | 02:44 AM
si0385.'s Avatar
now it will only start and run ok if i unplug the ecu for like 10 seconds and plug it back in
Old Oct 13, 2006 | 11:13 AM
sql_civic's Avatar
Default Re: (si0385.)
What over mods have you done to the car. Why are you using the P28? Custom tuning?
Try running the car with a P2E or P2P or whatever ODB2 ECU came with your car.
Try fixing the 41 CEL.
I also had wierd problems starting when my harness was not tightly grounded at the thermostat housing.
Old Oct 13, 2006 | 01:52 PM
si0385.'s Avatar
Default Re: (sql_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sql_civic &raquo;</TD></TR><TR><TD CLASS="quote">What over mods have you done to the car. Why are you using the P28? Custom tuning?
I also had wierd problems starting when my harness was not tightly grounded at the thermostat housing.</TD></TR></TABLE>
i have yet to check grounds good idea though.. its just a stock p28
it did it agian tihs morning and i unpluged the ecu for 10 seconds pluged it back in and it ran... :weird:
Old Oct 13, 2006 | 07:44 PM
sql_civic's Avatar
I'm not sure I get what you got going on here. Why the OBDII to OBDI conversion? If your car is a 98 you should just run the straight ODBII unless you've made mods like FI or N/A high compression.
Code 41 is a serious problem. It indicates a problem with the primary HO2 sensor or with the related wiring. This sensor provides critical feedback to the ECU so it can regulate the proper air/gas mixture runnng our engine. It's very possible that the ECU has decided to go into "limp mode" which means it is bypassing the feedback info and using preset air/fuel values. When you reset the ECU you could be deactivating limp mode for a shot while.
Start by checking if your primary ECU is plugged or there are no wires loose. Then you might go out and get a new HO2 sensor.
TNight
Dec 28, 2016 04:47 PM
seattleslew
Jun 4, 2013 04:41 PM
DC2-ProdUcTiOnS
May 3, 2010 12:49 PM
99em1_sir
23
Dec 6, 2007 08:24 AM
