Help (searched) Resistor box install in 92-95 civic With H22
Old Oct 12, 2006 | 02:15 PM
kauaiboy66's Avatar
Default Help (searched) Resistor box install in 92-95 civic With H22
I dont know where to post this so I'll post it here..
My friend has a 92-95 civic EG with an h22 and I'm about to wire a resistor box from an accord.. and I know that 4 wires go to the injector but waht side the positive or the negative... an is the other wire going to the ingnition....
let me know...
Thanks in advance
Old Oct 12, 2006 | 04:36 PM
kulrevon's Avatar
Default Re: Help (searched) Resistor box install in 92-95 civic With H22 (kauaiboy66)
http://www.homemadeturbo.com/t....html
you cut the yellow/black wire from each injector and wire in the resistor. it is the power wire from the ecu.
Old Oct 16, 2006 | 01:24 AM
kauaiboy66's Avatar
Default Re: Help (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">http://www.homemadeturbo.com/t....html
you cut the yellow/black wire from each injector and wire in the resistor. it is the power wire from the ecu.</TD></TR></TABLE>
so the other wire is a remote or battery? thanks for your help
Old Oct 16, 2006 | 09:16 AM
kulrevon's Avatar
Default Re: Help (kauaiboy66)
what other wire?
Old Oct 16, 2006 | 03:37 PM
kauaiboy66's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">what other wire?</TD></TR></TABLE>
the other wire besides the 4 that go the injectors...
thanks
Old Oct 17, 2006 | 06:06 AM
kulrevon's Avatar
its a positive that comes from the ecu. I believe (this is off the top of my head so i get be positive) you can use the wire that powers the iac and the o2 sensor? maybe yellow/black?????.
I would go to the civic section you are more likly to find some who has done this. preludes already have resistors so we never have to modify them.
or look up vafc hack ??
Old Oct 18, 2006 | 03:23 AM
kauaiboy66's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">its a positive that comes from the ecu. I believe (this is off the top of my head so i get be positive) you can use the wire that powers the iac and the o2 sensor? maybe yellow/black?????.
or look up vafc hack ??</TD></TR></TABLE>
Thanks for your help....
kholmes
Apr 13, 2005 09:49 PM
Magic Wheels
Jul 17, 2004 02:03 PM
Del_Slowest
Oct 21, 2003 08:20 PM
freeplay
Oct 10, 2002 12:16 AM
