Anybody on the board have a Flywheel on their GS-R?
Old May 3, 2002 | 11:28 AM
Acronym's Avatar
Default Anybody on the board have a Flywheel on their GS-R?
Just wanna know alittle information some pros & cons....
Old May 3, 2002 | 11:38 AM
vtec69's Avatar
Default Re: Anybody on the board have a Flywheel on their GS-R? (Acronym)
i have one! its great! the one big pro is that it keeps my car running! the only con is that mine isn't lightened!
http://www.howstuffworks.com/clutch2.htm
Old May 3, 2002 | 11:41 AM
NWPNOMORE's Avatar
Banned
Default Re: Anybody on the board have a Flywheel on their GS-R? (vtec69)
Old May 3, 2002 | 11:43 AM
Dirty GS-R's Avatar
New User
I knew that was coming.
Old May 3, 2002 | 11:51 AM
reno96teg's Avatar
I would hope that everyone here has one.. even the non GS-Rs.
Old May 3, 2002 | 11:52 AM
drumsy's Avatar
New User
Default Re: Anybody on the board have a Flywheel on their GS-R? (2K1 GS-R)
Fidanza 9lb Flywheel from Enjuko Racing via Group Buy Center. Installed same time as Exedy Organic Clutch from one of H-T's sponsor's, http://www.clutchcityonline.com. No cons that I can think of, lighter rotational mass, so I can climb up the gears a tad bit faster now.
Old May 3, 2002 | 11:58 AM
integRated109's Avatar
i have a CM7.5lb in my ITR, i love it, but ive already eaten up the replacable friction plate, and the replacement one was like 70 bux. i think i just did a half *** clutch break in last time because it should have lasted longer than 6 months.
Old May 3, 2002 | 12:15 PM
Acronym's Avatar
Default Re: Anybody on the board have a Flywheel on their GS-R? (integRated109)
Alright thanks alot ill take a look into the website a few of u requested....Later
Old May 3, 2002 | 01:36 PM
redman223's Avatar
I've been running a clutchmasters in my hatch for awhile now and its been great, no complaints from me.
Old May 3, 2002 | 01:40 PM
reefer_bob's Avatar
Default Re: Anybody on the board have a Flywheel on their GS-R? (redman223)
Comptech 6.75# lb Aluminum Flywheel. ACT HD Pressure Plate, SS Clutch.
How did you know you were in the friction surface so soon? Did it start to give?
Old May 3, 2002 | 02:50 PM
Default Re: Anybody on the board have a Flywheel on their GS-R? (reefer_bob)
actually it was squeeking pretty bad whenever i rode the clutch. then i broke 2 pistons on 8psi and had to pull the motor out. my clutchnet 2 was all tore up and the plate had some deep gouges in it.
Old May 3, 2002 | 03:08 PM
ragejed's Avatar
9.1 toda, ACT HDSS clutch disc/plate
love it, just hope i broke it in right too, i went pretty easy for my 1k miles, never went over 4 during the first 400, then went up 100 rpms with each 100 miles...
hope its ok...u guys think soo? i never let fo of the clutch too fast, i made it nice and smooth slippin
Old May 3, 2002 | 03:20 PM
MikeSarr_GSR's Avatar
Default Re: Anybody on the board have a Flywheel on their GS-R? (ragejed)
I tell you what, if the clutch starts slippin you are gonna know it!!!
Never had a slippin clutch on my Teg, but felt it in my 86' 2.0Si Lude...
reeeeeaaaa...... not fun. I have an ITR OE fly with a ACT HD/SS also.
I like it a loh... its 15lbs, but on my next disk I may go lighter with a
6puck on the same pressure plate. Who knows when that will be!
The GSR one for refrence is pushing 20lbs... mine is a bit clacky when
I idle with the AC on even @ 15lbs! For those lighter than that try it and see...
I doubt that you dont have at least that negative issue. It took adding
more tq. to the engine at idle to make that happen. I added more cam
and more air and some head and valve work, next thing I know... a
clacky flywheel! My buddy has a Supra with an ungodly amount of TQ.
He had a super light one and that thing sounded like a symphony of
spun rodbearings.
My .02
[Modified by MikeSarr_GSR, 12:24 AM 5/4/2002]
Old May 3, 2002 | 07:42 PM
D.Lansing's Avatar
Default Re: Anybody on the board have a Flywheel on their GS-R? (MikeSarr_GSR)
Toda FW here, I like it.
Old May 3, 2002 | 08:18 PM
IN VTEC's Avatar
Default Re: Anybody on the board have a Flywheel on their GS-R? (D.Lansing)
Toda too.
Old May 4, 2002 | 09:25 AM
scribnits's Avatar
Default Re: Anybody on the board have a Flywheel on their GS-R? (IN VTEC)
I have a Spoon flywheel....I love it, no complaints here.
austinwasthere
Mar 25, 2014 07:02 PM
LSTEG96
Dec 8, 2005 06:49 AM
Anthonyl469
26
Jul 22, 2004 10:29 AM
domepizzle
Jun 14, 2003 06:14 PM
