is this brake rotor defective??
Old Oct 12, 2006 | 02:57 AM
an2ny888's Avatar
Default is this brake rotor defective??
just got this rotor yesterday, i noticed this chip on the side when i was about to install it. is this a defective rotor? or is this a balancing feature?
Old Oct 12, 2006 | 03:33 AM
Dave_B's Avatar
I don't think I've ever seen one with that cut in it. I would take it back and play it safe.
Old Oct 12, 2006 | 03:54 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (Dave_B)
wtf?
ummm where did you get them and what kind are they?
Old Oct 12, 2006 | 04:11 AM
eg6ajk's Avatar
Default Re: is this brake rotor defective?? (an2ny888)
that normal, at least from the ones I have seen. I purchased few new rotors of acura, and some had it, some did not !
Old Oct 12, 2006 | 04:51 AM
Willard's Avatar
it is fine... that is how they balance them.
these are defective:
Old Oct 12, 2006 | 05:10 AM
Willard's Avatar
Default Re: is this brake rotor defective?? (Willard)
sometimes they place metal wires in-side of the vent holes to balance them (vs. machining them).
Old Oct 12, 2006 | 06:57 AM
walker111's Avatar
Yes, perfectly normal.
Old Oct 12, 2006 | 07:00 AM
an2ny888's Avatar
Default Re: is this brake rotor defective?? (walker111)
ok i'll just install it, tnx a lot for the feedback
Old Oct 12, 2006 | 07:11 AM
BMaDOHC's Avatar
I believe they use that on some rotors so you know how much you can machine them without over doing it.
Old Oct 12, 2006 | 10:17 AM
jdmspoonitr's Avatar
Default Re: is this brake rotor defective?? (BMaDOHC)
I bought some Brembo rotors off a guy on HT and there was a sizable nick missing from the face of the rotor on the outer edge.....It has gotten a little bigger....fark
Old Oct 12, 2006 | 05:16 PM
igyloo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">sometimes they place metal wires in-side of the vent holes to balance them (vs. machining them).</TD></TR></TABLE>
I pulled a metal wire out of my rotor before
Old Oct 12, 2006 | 06:00 PM
mugenracer's Avatar
I noticed the same thing on rotors i bought a while back and brought them back only to be told that it was normal and was for balance...i was figuring it wasnt a piece missing as the both faces of the disc were cut exactly the same and there was no rough edge like a bit had chipped out of it but i wanted to be sure....fitted them and they were fine.
Old Oct 12, 2006 | 06:23 PM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">it is fine... that is how they balance them.
i would not call those defective.............just well used
edit: and part of the reason they do not offer a lifetime warranty anymore
Damanzi
Suspension & Brakes
Jan 9, 2012 12:03 PM
pyork03
Honda Civic (2001 - 2005)
Jun 25, 2007 05:29 PM
ViZ
Feb 19, 2005 09:43 AM
-16V-
Mar 13, 2004 10:01 PM
oryanh
Jan 4, 2004 01:38 PM
