misfiring/bogging while driving? @ 6k
Old Oct 11, 2006 | 07:45 PM
99blackdc2's Avatar
Default car now hesitates/boggs before 3k...i searched and nothing describes my problem
my stock 99 gsr with new plugs, wires, cap, rotor and fuel filter hesistates while approaching 3k in all gears at light throttle. if i step down on the pedal it will pass the bogg and pick up and rev like it should. i dont kno where else to check...timing should be dead on but im going to double check tomorrow...i was told to check my O2 sensors but aside from that any other suggestions
Modified by 99blackdc2 at 10:16 PM 10/19/2006
Old Oct 11, 2006 | 09:40 PM
JDM94EG28's Avatar
Default Re: misfiring/bogging while driving? @ 6k (99blackdc2)
WHEN THE LAST TIME YOU CHANGE THOSE PLUG'S,CHECK YOUR ROTOR CAP AND PLUG'S SEE WHAT CONDITON THERE ARE IN..CHECK CEL CODES..START FROM THE LITTLE THING'S 1ST
Old Oct 11, 2006 | 10:32 PM
99blackdc2's Avatar
Default Re: misfiring/bogging while driving? @ 6k (JDM94EG28)
plugs, wires, cap, rotor all les then 1 month old and like i said no check engine light
Old Oct 12, 2006 | 03:33 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: misfiring/bogging while driving? @ 6k (moops vs moors)
Check your map sensor connector and the sensor itself. Also, was the fuel filter changed?
Old Oct 12, 2006 | 07:52 PM
99blackdc2's Avatar
Default Re: misfiring/bogging while driving? @ 6k (JDM_Ej)
fuel filter is recent also...any more suggestions on what to check for wen i go to my car tomorrow any kind of vacuum problems that would cause this? i just need to locate whats causing this...ive been rockin the bicycle all week and my legs are hurtin!
for the suggestions, all u guys are great help
Old Oct 13, 2006 | 07:56 AM
99blackdc2's Avatar
unplugged ecu...disconnected battery...if i didnt love my teg so much id blow it up...way too many random/minor problems im too retarded to fix...check engine light lites up during bulb test but no cel code for the misfire
Old Oct 13, 2006 | 12:14 PM
hitekper4mance's Avatar
how long have you had this problem??
Old Oct 13, 2006 | 12:21 PM
ToolAuctions's Avatar
If all that was just replaced, did you do it or someone else? Also, something might have been done wrong, so those are actually the first areas I recommend to look, becuase that is what is often overlooked.
Old Oct 13, 2006 | 03:26 PM
99blackdc2's Avatar
i did it...i swear i didnt mess up...but ill look it over again...the help is appreciated
Old Oct 16, 2006 | 12:13 PM
99blackdc2's Avatar
i never took it to WOT i was too afraid that sumthing was going to break lol...ill check for a code again...hopefully it is ignition. im going to check the map and tps with a multimeter as well as the wires and the ignitor....
Old Oct 19, 2006 | 07:43 PM
99blackdc2's Avatar
Default Re: car now hesitates/boggs before 3k...i searched and nothing describes my problem (99blackdc2)
bump
Old Oct 19, 2006 | 09:23 PM
jspec-integ Ls's Avatar
did u gap your spark plugs correctly to spec???
Old Oct 20, 2006 | 07:56 AM
99blackdc2's Avatar
yes i did...i was having problems with it misfiring at 6k and that stopped but now theres a bog/hesitation right before 3k but i can pull thru the bog if i step on the gas more
Old Oct 28, 2006 | 08:40 PM
dynamitezz's Avatar
Default Re: (99blackdc2)
I have had the same problem fixed all sorts of things still lost on what it is
coco718
13
Oct 5, 2011 02:27 PM
h_civ2000
35
Oct 20, 2009 04:15 PM
Takashi1978
Aug 10, 2005 07:44 AM
Hybrid Boy
Sep 1, 2002 03:16 PM
