A/c removal
Old Oct 11, 2006 | 07:43 PM
Lavisracing's Avatar
Default A/c removal
So i am removing my A/c cause its messed up as is i am wondering what all is needed to remove the compressor?? any help? i think it has the idler on the same belt. It's a 92 GS Hatch
Old Oct 11, 2006 | 07:46 PM
Default Re: A/c removal (Lavisracing)
bump for help...
Old Oct 11, 2006 | 07:51 PM
can anyone help me?
Old Oct 11, 2006 | 07:57 PM
do i need an A/c omit pulley? or is there a different belt to use?
Old Oct 11, 2006 | 08:03 PM
CleanLikeJdm's Avatar
Hype-R Stalker
The a/c should have it's own belt, just unbolt everything, no trickery to it.
Also, you don't Need anything to actually remove it, all you really need is the wrenches/sockets,
you don't have to Replace anything to take the a/c out.
Old Oct 11, 2006 | 08:05 PM
Default Re: A/c removal (CleanLikeJdm)
i believe the idler is on the same belt is this a problem?
Old Oct 11, 2006 | 08:09 PM
Hype-R Stalker
The pulley that pulls tension on the belt for the a/c?
If that's what you mean, then it is not a problem, it's only for the a/c.
You have different belts for each accessory, p/s, a/c, and alternator.
Old Oct 11, 2006 | 08:12 PM
yes i understand its a tri-belt crank i read the haynes for the car it says its a tension idler... thats why i asked
Old Oct 11, 2006 | 08:16 PM
Hype-R Stalker
That tensioner is pretty much attached to the mount that the a/c is on,
which is also part of the lower engine mount right?
If you're taking the a/c out, cut the belt(if you haven't already), and go from there.
It's Very straight-foward, all you do is unbolt it.
Old Oct 11, 2006 | 08:19 PM
ok awesome thanx then all the parts left are the compressor and the part under the pass. dash. Thanx a lot...
Old Oct 11, 2006 | 08:23 PM
Hype-R Stalker
The compressor can be taken off, if you're referring to the one with the pulley on the end of it, lol.
Just take everything out of the engine bay, and when you get back to the firewall where the lines go into the cabin,
Just unbolt them, and leave that piece inside the car.
Otherwise you'd have to get some piece from an RS model to replace it inside.
Old Oct 11, 2006 | 08:25 PM
ok thanx ill do that tomorrow when im changin the oil...
redm3turbo
Aug 18, 2015 04:59 PM
OOOtony
Sep 25, 2007 07:56 PM
kit50si
Aug 14, 2007 09:31 AM
Threads
Oct 8, 2004 12:37 PM
SpoolnG2
Dec 16, 2002 04:53 PM
