Skunk2 intake manifold TECH Question!!!!!
I bought a skunk2 intake manifold. UPon starting after installation, the car immediately starts to rev higher and higher and i i shut it off. I checked everything about 36 times and i cant figure it out. Need Help and suggestions???
96 gsr
96 gsr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr »</TD></TR><TR><TD CLASS="quote">happened to me when i installed mine, its going to be the throttle cable, check it, it's hitting the hood, </TD></TR></TABLE>
No the hood is up when this happens!
Check all your vacuum and coolant lines. Also check to make sure you installed the correct plug to the correct sensor, i.e. tps, map sensor, etc.
Also what hose goes on the little secondary coolant line fitting located on the mounting bracket mine only had the larger hose and with everything hooked up (CORRECTLY NOW, THANKS) the little secondary one doesnt have anything to connect too and i have already bypassed the hose to the intake when i installed my CAI. Do i jUst plug it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KYDC2 »</TD></TR><TR><TD CLASS="quote">Also what hose goes on the little secondary coolant line fitting located on the mounting bracket mine only had the larger hose and with everything hooked up (CORRECTLY NOW, THANKS) the little secondary one doesnt have anything to connect too and i have already bypassed the hose to the intake when i installed my CAI. Do i jUst plug it?</TD></TR></TABLE>
BUMP
BUMP
d_mina
Jul 20, 2004 08:07 AM
obd2gsr
Oct 23, 2003 10:19 AM
