GSR front/rear discs on my 92 dx hatch, brake booster, master cylinder, which fits?
was thinking if i should keep the same stock ones, and get 4040 porportioning valve? or if i should also replace my brake booster and master cylinder with that of a gsr?
searched, lots of topics on different setups, not this exact.
WTF is your question??!!???
Everything off a 94+ integra will fit on a 92+ civic
Regardless changeing to a gsr master and booster will give u a lot more braking power
Get 94+ GSR knuckles with the rotors and brakes
IF u do rear disc conversion then y change the to the 40/40 prop valve
I would also suggest steel braided lines gets rid of spungy pedel
need new pads... autozone sells ones called PFC's dam good ....$40 or so... lifetime waranty
after searching for a bit more, i found my answer. i already have the front/rear brakes installed, i just needed to know which MC/BB i need. thanks.
https://honda-tech.com/zerothread?id=1036267
https://honda-tech.com/zerothread?id=1444738
pouponu
Feb 10, 2008 10:55 AM
CivicVX94
16
Oct 17, 2007 07:40 PM
ben_eg6
12
Dec 11, 2004 05:07 PM
