does a 97" civic stock motor have a FITV?
Old Oct 11, 2006 | 01:45 PM
hatchback1997's Avatar
Default does a 97" civic stock motor have a FITV?
I have a problem with the idle going up and down 1000-2500rpm. I search for a 97 civic stock motor but no results. Already replaced the IAC valve (#2 in diagram), still no luck. does it have a Fast Idle Valve?
Old Oct 11, 2006 | 02:53 PM
2wheelhunter's Avatar
Default Re: does a 97" civic stock motor have a FITV? (hatchback1997)
sounds like a simple vacuum problem, i have no clue wich vac line but test a couple make sure there not clogged, also check ur TPS, u can find the correct voltages for it on honda-tech somewhere... hope this helps
Old Oct 11, 2006 | 02:57 PM
Syndacate's Avatar
There is NO FITV in '96+ civics.
Sounds like a vacuum leak.
Old Oct 11, 2006 | 03:46 PM
Thanks guys, I'll check it tonight.
borrego805
Feb 14, 2015 04:28 PM
happy123
May 21, 2009 03:11 PM
eJ6DM
Nov 25, 2005 10:10 PM
Alphi
Jan 8, 2005 10:37 PM
